Online Now [989]:
Visitors: 988
Today: 279714
Total: 149030773
Forums › The Car › 206 Problems › Morette headlight adjustment
bazzaboy1977
PostPosted: Thu Nov 22, 2012 2:44 pm Up
I don't know if anyone can help i have a set of morette lights fitted to my 206 and it passed the mot but now the nights have pulled in the lights are so bad it's like they are not on i didn't know if you can adjust them as when you look at the lights the optics are showing what looks like metal on the inner edge and I think they need adjusting from left to right not up and down any help would be great full
bmace
PostPosted: Thu Nov 22, 2012 2:45 pm Up
Don't think you can adjust morettes, if so I diddnt know you can
I have the same problem I cannot see more than like 1 metre ahead, I purchased some HIDs which have helped very slightly ...
bazzaboy1977
PostPosted: Thu Nov 22, 2012 2:50 pm Up
How much are the kits as I have seen them on eBay starting from £18 but don't know how easy they are to fit
bmace
PostPosted: Thu Nov 22, 2012 2:55 pm Up
Well when buying HIDs you need to know the legalities before purchasing anything
You can find some info in the non legal section as to which ones you can't have. Also if you use the search bar I'm sure you'll find what you need to know
bazzaboy1977
PostPosted: Thu Nov 22, 2012 2:58 pm Up
I know it's all down on how bright they are it will be 6k or 8k are the ones I'm looking at
bmace
marc206
PostPosted: Thu Nov 22, 2012 3:04 pm Up
i had morettes on mine and i could see fine with some osram nightbreakers :/
bazzaboy1977
PostPosted: Thu Nov 22, 2012 3:10 pm Up
I think that what i have in there £12 off amazon
bmace
PostPosted: Thu Nov 22, 2012 3:22 pm Up
there are some plastic things on them which you can use a philips screwdriver with to adjust the angle (left,right, up, down)
bazzaboy1977
PostPosted: Thu Nov 22, 2012 3:50 pm Up
I can only see 1 on each side
bmace
PostPosted: Thu Nov 22, 2012 4:21 pm Up
my bad, there's another one for the line type screwdriver to turn. next to yellow wire on middle optic.
img251.imageshack.us/i...214615.jpg
bazzaboy1977
PostPosted: Thu Nov 22, 2012 4:55 pm Up
Ok I will give it a try Saturday in the day light
bmace
