Online Now [256]:
Visitors: 256
Today: 24677
Total: 142535139
Forums › The Car › 206 Problems › Car won't go into gear
Povall_555
PostPosted: Fri Nov 23, 2012 3:26 am Up
the car won't go into gear, and shakes violently when pulling away/changing gear. The clutch is only 6 months old so any ideas what the problem could be?
Cheers
Cheers for the help!!
PostPosted: Fri Nov 23, 2012 5:53 am Up
i would checked the engine mount
LORDPSK
PostPosted: Fri Nov 23, 2012 12:34 pm Up
Did they replace the trust bearing and preassure plate at the same time?
Peugeot 206
dan.brown.120393
PostPosted: Fri Nov 23, 2012 4:40 pm Up
Is the gear linkage set up properly?
Dan Brown
DeadEyePaul
PostPosted: Fri Nov 23, 2012 4:57 pm Up
Does it go into gear when engine is off then started in gear?
