Latest: jackrox1992
Overall: 17186
Online Now [1034]:
Visitors: 1033
Today: 73857
Total: 148838427
Forums › The Car › 206 Problems › coilovers will not adjust!
Go to page Previous  1, 2
138Andy
PostPosted: Tue Nov 27, 2012 4:45 am Up
i can post you a load of wire toothbrushes if you want, free of course
PostPosted: Tue Nov 27, 2012 8:42 am Up
Brushes wont help clean the threads under the lockrings. Needs grease on the threads after you've loosened them.
gazza82
PostPosted: Tue Nov 27, 2012 10:57 am Up
rttam wrote:
get the threads really clean and soak them for a few days in wd40 and oil.
You'll be a lot better off using penetrating oil ... WD40 is over-sold and pretty useless at this.
gazza82
PostPosted: Tue Nov 27, 2012 11:01 am Up
You might need to use TWO spanners ... one on the top ring, one on the lower. Chases are they've been overtightened and are jamming against each other and the threads now.
anton1989
PostPosted: Tue Nov 27, 2012 11:44 am Up
Trade Rating: +16
yh that would be good if you can so i can clean them up
anton1989
PostPosted: Tue Nov 27, 2012 11:46 am Up
Trade Rating: +16
not had time to do anythiing yet due to work and weather.
whats penetrating oil?
what shall i grease them up with after Edward? (what grease)
PostPosted: Tue Nov 27, 2012 12:23 pm Up
are you turning the two nuts opposite ways? eg top one right, bottom left?
hammer and bolster normaly works for me.
anton1989
PostPosted: Tue Nov 27, 2012 12:32 pm Up
Trade Rating: +16
tryed turning it both ways. will have another go at the weekend
PostPosted: Tue Nov 27, 2012 1:07 pm Up
it will be top one to right and bottom to left, i normally hold one of them with c spanner while other nut is hit with hammer and bolster by a mate (not got enough hands lol)
once the two nuts are apart they will move easy,.
One has to go up and one has to go down, not together in one direction Laughing
PostPosted: Tue Nov 27, 2012 1:39 pm Up
Penetrating oil finds it's way between the two seized components.
Any grease...copper grease...lard...anything that coats the threads to stop moisture and dirt getting into them.
anton1989
PostPosted: Tue Nov 27, 2012 1:45 pm Up
Trade Rating: +16
i see. the little spanner thing i have is s**t. its not fixed, it folds. should have done this while they were on the car!
also are these the v maxx coilovers? they any good? i got them free so might trial fit them?
PostPosted: Tue Nov 27, 2012 4:14 pm Up
I wouldn't put them on my wheely bin.
anton1989
PostPosted: Tue Nov 27, 2012 5:24 pm Up
Trade Rating: +16
I see what you did there Very Happy
PostPosted: Tue Nov 27, 2012 6:12 pm Up
get the bottom pic of the c spanner ( i think it cost only a few quid) and then hammer it until loosen.
Page 2 of 2
