Latest: tbafonso
Overall: 17130
Online Now [359]:
Visitors: 358
Today: 50130
Total: 104239755
Forums › The Car › 206 Problems › Pagid Discs and Pads- Euro Car Parts - Confussed??
Go to page Previous  1, 2
Tolkienfan001
PostPosted: Tue Nov 27, 2012 10:26 am Up
Trade Rating: +13
Edward wrote:
Have you used the Euro Car Parts discount code?
Pagid30?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Tue Nov 27, 2012 11:50 am Up
midmonth31
Sim
PostPosted: Wed Nov 28, 2012 4:42 pm Up
My sufferings ended when I went to www.brakesint.co.uk . First find your pads (remove your pug's wheel to see exactly which types of brake system pads you have)
Then find a matching set of disks by looking your pads up in a catalogue of either www.mintex.co.uk or www.brembo.com
It is crucial to do the above, as different brake systems might be fitted on same engine same year type Peugeots! And then you end up with 0.5mm thicker disks which don't fit in
All the best with your quest!
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
bezford
PostPosted: Thu Nov 29, 2012 8:53 pm Up
there's also another for batterys it is battery15 for 15%
R.HYDE
PostPosted: Fri Nov 30, 2012 2:06 am Up
Is this subject really still going? Have the new bits been bought yet? It's possibly the easiest items to buy correctly.
Tolkienfan001
PostPosted: Fri Nov 30, 2012 2:39 am Up
Trade Rating: +13
Yea got Vented discs and pads from local place £50.00 total (Vented discs x 2 + pads) Not to bad. Just got to fit them now. Jobs are piling up. Stupid weather!!
2005 1.4 16v Sport
Sim
PostPosted: Fri Nov 30, 2012 7:22 am Up
I bought drop links, wheel hub and bearing, abs sensors, all filters etc.they all fitted fine, buy when brake disk doesn't fit by a fraction, and ordered kit states your make model engine and year, wouldn't fall in an easiest-items-to-buy-correctly category
EV
GTC VXR (sold)
Tolkienfan001
PostPosted: Fri Nov 30, 2012 7:26 am Up
Trade Rating: +13
What He Said
2005 1.4 16v Sport
Page 2 of 2
