Posted: Sat Dec 01, 2012 6:22 am |
will a normal code reader reed it? and is it the black and green plug to the lower right of the steering wheel behind the panel and next to the fuse box. thanks
Posted: Sat Dec 01, 2012 6:26 am |
Yes it will read the P codes.
HDI GTI, FAPTASTIC
Posted: Sat Dec 01, 2012 6:28 am |
i have pluged a snep on code reader into the port where i said it is but the reader said no comunication?
Posted: Sat Dec 01, 2012 6:34 am |
vickys.hdi.gti wrote: |
i have pluged a snep on code reader into the port where i said it is but the reader said no comunication? |
Snap On are not the best at diagnostics
Any 2004 onwards built diesel will be EOBD, any EOBD code reader should connect & be able to pull the fault codes from the memory.
NOTE: Ignition needs to be switched ON to get comms with the engine ecu else the immobiliser will block access to the code reader.
Peugeot Planet / Diagbox would be the ultimate thing to use on this.
Posted: Sat Dec 01, 2012 6:47 am |
yes i did have it switched on but not running. is that the correct plug then?
Posted: Sat Dec 01, 2012 6:50 am |
is that the correct plug then? |
Yes.
Either try another EOBD code reader OR try & find someone with Peugeot Planet / Diagbox to scan it instead.
I take it the car runs but the diagnostic light is on?
Posted: Sat Dec 01, 2012 7:05 am |
the light comes onand goes off every other week. car runs the same. it was a little flat though the last time it came on, limp mode but then it was ok.
Posted: Sat Dec 01, 2012 7:12 am |
Find someone with Planet / Diagbox OR just buy Planet / Diabox yourself, it's best run on Windows XP.
Its the diagnostic leads that cost, the software is available free if you know where to look / who to ask BUT the software would come with the leads anyway.
Posted: Mon Dec 17, 2012 3:55 am |
sorry to jump in to a conversation,
can you guys tell me what reader
I need to get for my pug rolland garros W-Reg (2000)
Regards
Dom.....
Posted: Mon Dec 17, 2012 5:48 pm |
If anyone intetested looks on amazon website they have a wide range of code readers ranging from £8.50. Upto £450.00 suiting all pockets but as the addage goes..you get what you pay for...
