Latest: tbafonso
Overall: 17130
Online Now [64]:
Visitors: 63
Today: 1017
Total: 104510698
Forums › The Car › 206 Problems › New clutch Fitted, revving when Clutch pushed in?
NayNay1991x
PostPosted: Mon Dec 03, 2012 1:36 pm Up
Hey guys, as some as you know just had clutch fitted, 206 is running so smooth now but whenever im driving and push the clutch in when coming to a stop there's slight engine Rev.
I noticed there's a screw maybe a limit screw on the accelerator do i release some tension or?
PostPosted: Mon Dec 03, 2012 1:39 pm Up
Probably picks up a few revs because it's not having to spin the gearbox internals.
NayNay1991x
PostPosted: Mon Dec 03, 2012 1:40 pm Up
Normal then or? As its idling just over x100
Smile
206 1.4i GLX 1999
instagram.com/nay206pug/#
Mattie-RS
PostPosted: Mon Dec 03, 2012 1:59 pm Up
I thought all modern cars held there revs for a second when you engage the clutch
NayNay1991x
PostPosted: Mon Dec 03, 2012 2:11 pm Up
How modern Razz 1999? Could be me i guess Smile
206 1.4i GLX 1999
PostPosted: Mon Dec 03, 2012 3:49 pm Up
Idle should be 750rpm after 10 minutes from cold +/- 50rpm.
Don't mess with the throttle cable at all.
Get used to driving it and see if it's you or the pug at fault.
PostPosted: Mon Dec 03, 2012 4:17 pm Up
The engine ecu is programed to do that.
Engine ecu sees the car is still moving from the speed sensor so it raises the idle speed slightly.
NayNay1991x
PostPosted: Tue Dec 04, 2012 1:05 am Up
Isnt it supposed to help from what i read, as you shift from 1st it climbs abit to get in 2nd
206 1.4i GLX 1999
bezford
PostPosted: Tue Dec 04, 2012 9:11 am Up
Race car drivers often give it a.blip before selecting a gear.
R.HYDE
