Forums › The Car › Solved 206 Problems › Changed alloys terrible noise |
Posted: Sat Dec 22, 2012 10:18 am |
Trade Rating: +13
Just had a thought. The car they came from was a written off GTI. Middle engine front end damage. Could it be flat spots on the tyres from the braking during the crash?
Last edited by Tolkienfan001 on Sat Dec 22, 2012 10:32 am; edited 2 times in total
Posted: Sat Dec 22, 2012 10:30 am |
Quite possibly this ^^^
Posted: Sat Dec 22, 2012 10:31 am |
Trade Rating: +13
How do I check for flat spots?
Posted: Sat Dec 22, 2012 11:24 am |
You'd feel flat spots more than anything...I imagine it must be the tyres or the tyres have worn unevenly - possibly. Maybe it's normal and the wider tyres just make more noise.
Posted: Sat Dec 22, 2012 12:51 pm |
Trade Rating: +13
Solved it!! Front left was unevenly worn. Swapped with the back no rumble!!
