Online Now [372]:
Visitors: 371
Today: 97140
Total: 106291273
Forums › The Car › 206 Problems › tyre pressure
tyre pressure
kizza93
PostPosted: Sun Dec 23, 2012 1:27 pm Up
what tire pressure should i be using i have low profile tyres 205/40/r17
anton1989
PostPosted: Sun Dec 23, 2012 3:33 pm Up
Trade Rating: +16
i use 33
novatron1_2
PostPosted: Sun Dec 23, 2012 4:06 pm Up
have a play using the standard pressure, higher pressures give an increase in handling until a pint when the tyre's contact patch is reduced
206 1.9D, 210,000 now dead following failed submarine experiment (flood)
LORDPSK
PostPosted: Sun Dec 23, 2012 5:42 pm Up
Check with the tyre manufacturer for his recommendations
Peugeot 206
HDI90
PostPosted: Mon Dec 24, 2012 3:37 am Up
all 206,s are 33
GTI 180
anton1989
PostPosted: Mon Dec 24, 2012 3:59 am Up
Trade Rating: +16
HDI90 wrote:
all 206,s are 33
Regardless of wheel size? If you have the standard wheel that come woth the car it says on the car in the door part where the paint code is
138Andy
PostPosted: Mon Dec 24, 2012 6:24 am Up
it will say on the wall of the tyre Smile
Mattie-RS
PostPosted: Mon Dec 24, 2012 7:06 am Up
Does it?? Must have been doing it wrong all those times with lower pressure to increase in grip/handling
bezford
PostPosted: Mon Dec 24, 2012 7:13 am Up
32-34all day long.
R.HYDE
Mattie-RS
PostPosted: Mon Dec 24, 2012 8:16 am Up
23 fronts 25 rears Wink
PostPosted: Mon Dec 24, 2012 9:52 am Up
72 psi
bezford
PostPosted: Tue Dec 25, 2012 5:35 am Up
Howay stop pixxin about its 32 to 34...sorry for the lack of humour because sayin 25 and 72 must of been a joke..ha ha...not.
R.HYDE
Mattie-RS
PostPosted: Tue Dec 25, 2012 9:09 am Up
Sorry I must have forgot to laugh, hahahahahaha, No! that's what I actually run Wink
PostPosted: Tue Dec 25, 2012 9:57 am Up
Where? Do all tyre manufacturers make 1 size of tyre to fit 1 make and model of vehicle?
You're getting confused with the maximum pressure marking.
novatron1_2
PostPosted: Thu Dec 27, 2012 5:52 pm Up
That's interesting, I've always found the opposite, here's a good article:
www.modified.com/tech/...ewall.html
Part of it says:
How does a tuner manipulate tire loading and slip angle? By tweaking the spring rates, anti-roll bar rates, tire sizing and pressure, and to a lesser degree, the shock damping. The first option a tuner has is to increase the tire pressure. The harder a tire is inflated, within reason, the smaller slip angle it develops. In the case of a nose-heavy front-wheel-drive car, if you add several psi to the front tires and take some pressure out of the rear, the front tires will run a smaller slip angle while the rear tires' slip angle will increase. This alone can do quite a bit to reduce understeer.
So it's saying you can make the back 'looser' by running less pressure and make the front grip better by running more pressure.
