Online Now [58]:
Visitors: 56
Bots: 2
Today: 8837
Total: 106138574
Forums › The Car › 206 Problems › Perminent Live???
Perminent Live???
djoggie
PostPosted: Fri Dec 28, 2012 3:17 am Up
Hi all.
Ive just installed a new Head Unit but it wont work.
Halfords have said i need to take the cable attatched the the rest of the cables to a perminant live? there is a ignition switch already there but i need a perminant live for the memory???
I have got the cable to under the steering wheel on my 206 but not sure how to identify a live?
i hate driving without music and i do alot of driving for work....
i start work again on wednesday so need this done asap!
any help would be appreciated!
DeadEyePaul
PostPosted: Fri Dec 28, 2012 4:21 am Up
If you put it on perminate live every time you would start the car the battery would be flat- they must of of said ignition live
djoggie
PostPosted: Fri Dec 28, 2012 4:22 am Up
so which is the ignition live?
DeadEyePaul
PostPosted: Fri Dec 28, 2012 4:23 am Up
When the key is turned the headunit has power
djoggie
PostPosted: Fri Dec 28, 2012 4:28 am Up
but my last head unit had power when the key was turned but thisone hasnt?
DeadEyePaul
PostPosted: Fri Dec 28, 2012 4:29 am Up
Probably burnt the fuse that was my first guess
djoggie
PostPosted: Fri Dec 28, 2012 4:33 am Up
halfords have said a need a perminant live?
DeadEyePaul
PostPosted: Fri Dec 28, 2012 4:35 am Up
No you don't otherwise every time you'd start your car it won't due to a flat battery- check fuses
djoggie
i put my old radio back in and it works.... so how could it be fuses?
DeadEyePaul
PostPosted: Fri Dec 28, 2012 4:36 am Up
How could it be perminate live then?
djoggie
PostPosted: Fri Dec 28, 2012 4:37 am Up
i need a perminant live for the memory of the unit? stops it going back to factory settings?
DeadEyePaul
PostPosted: Fri Dec 28, 2012 4:38 am Up
Ahhh just a sec need to find a photo
DeadEyePaul
PostPosted: Fri Dec 28, 2012 4:40 am Up
Do you have a connector like this?
You need red going into yellow
djoggie
PostPosted: Fri Dec 28, 2012 4:42 am Up
reds going to red and yellow is going to yellow. swap them round?
DeadEyePaul
Yep
