Latest: tbafonso
Overall: 17130
Online Now [378]:
Visitors: 377
Today: 11648
Total: 102483920
Forums › The Car › 206 Problems › Perminent Live???
Perminent Live???
Go to page Previous  1, 2
djoggie
PostPosted: Fri Dec 28, 2012 4:56 am Up
you are a genious mate! thank you soo much! best xmas present ever! cheers Smile
DeadEyePaul
PostPosted: Fri Dec 28, 2012 4:57 am Up
Good good Wink have a good new year!
PostPosted: Fri Dec 28, 2012 5:03 am Up
What a thread! You bickered like hell, then were best mates! Red and yellow swap was my first guess, been covered a hundred times before!
djoggie
and you!
PostPosted: Fri Dec 28, 2012 6:28 am Up
Puppy Love? Rolling On The Floor Laughing
DeadEyePaul
PostPosted: Fri Dec 28, 2012 6:37 am Up
The op didnt explain properly that it was a memory issue, simply said it's not working and needed a permanent live...
Wasn't until later memory was the issue
PostPosted: Fri Dec 28, 2012 7:06 am Up
djoggie wrote:
Hi all.
Ive just installed a new Head Unit but it wont work.
Halfords have said i need to take the cable attatched the the rest of the cables to a perminant live? there is a ignition switch already there but i need a perminant live for the memory???
I have got the cable to under the steering wheel on my 206 but not sure how to identify a live?
i hate driving without music and i do alot of driving for work....
i start work again on wednesday so need this done asap!
any help would be appreciated!
OP quite clearly says memory is the issue. Razz
PostPosted: Fri Dec 28, 2012 5:42 pm Up
djoggie wrote:
Hi all.
He forgot..
sme1973
PostPosted: Mon Jan 07, 2013 2:15 pm Up
Hi there, i had the same issue as i put in a sony head unit. When using a test meter on the car side of the wiring it showed i had a permanent live but after about 30 secs it turned of thus loosing all the settings. I had a few optins like running a live from the battery but i went for the easier option and spliced into the permanent live from the ignition barrel wiring (thick pink wire) and connected straighto the head units yellow wire. now all is fine.
Will
PostPosted: Wed Mar 20, 2013 10:02 am Up
DeadEyePaul wrote:
Do you have a connector like this?
You need red going into yellow
Hi mate, to swap these over, do you just pull them out of the connectors? I've never dealt with electronics before, so don't want to force something and break it lol, cheers.
DeadEyePaul
PostPosted: Wed Mar 20, 2013 10:06 am Up
Yeah pull outand swap them around
Will
PostPosted: Wed Mar 20, 2013 3:44 pm Up
All done, thanks. Was so easy I feel a bit daft for asking Laughing
DeadEyePaul
PostPosted: Wed Mar 20, 2013 3:48 pm Up
Its aliirght we all have to learn somewhere Wink
Will
PostPosted: Wed Mar 20, 2013 4:23 pm Up
Ha yes true. Thanks again, you've saved me roughly 1 minute of setting adjustment per journey for the entire time I have the car.
Page 2 of 2
