Latest: lio94
Overall: 17181
Online Now [121]:
Visitors: 120
Today: 8465
Total: 141505840
Forums › The Car › 206 Problems › 2001 3dr with no CL and NO way into the boot , help.
Royster
PostPosted: Sun Dec 23, 2012 11:36 am Up
I've had my 1.1 now for a lot of years and put up with the CL bouncing all the time but now it won't lock both doors, even with the key in the lock and now the boot lock won't release so I can't open the lid to put my tesco bags in, what a PITA.
Where should I look first ?
loud, proud and modified !
bezford
PostPosted: Sun Dec 23, 2012 5:36 pm Up
These are known for faults in the CL pack on the drivers side...i think thete is a how to advice post in the HOW TO forum thread...
R.HYDE
LORDPSK
PostPosted: Sun Dec 23, 2012 6:35 pm Up
The lock motor and interior light switch is all in one on the Peugeot unlike many other cars, open the doors and see which door the light does not work on, but you will probably end up changing both front door locks, but make sure you look at the wiring plug and get like for like as there is a few different types for that age of car.
The boot can be opened by lowering the rear seat backs, grasp the plastic cover on the tailgate and it just pulls off, you will then be able to slide the lock to the unlock position, normally just lack of oil on mechanism on tailgate lock
Peugeot 206
Royster
PostPosted: Mon Dec 24, 2012 3:37 am Up
If I slide the boot lock to unlock will it permanently be unlocked?
LORDPSK
PostPosted: Mon Dec 24, 2012 10:01 am Up
Yes unless you either use the key or remote and lock the car then it will relock, easier to leave the plastic cover off the inside of the tailgate till you have done repairs
Peugeot 206
Royster
PostPosted: Sun Dec 30, 2012 7:34 pm Up
Ok so today I finally got time to look at this, pulled the panel off and moved the latch over.
I could hear the sound of what I thought was an electric motor when I moved the latch, are these prone to failure?
I sprayed some wd-40 in the 'motor' and around the moving parts but it still didn't lock when I tried ! But I did hear something click,like a relay sort of click..
Ill ask another pair of hands to help to see am I getting any power at the 'motor' before I start buying anything for it.
