Posted: Tue Jan 01, 2013 11:54 am |
Noticed today a strange noise from the engine, it is only heard when i accelerate from 2k + its like a 'ticking noise' as you accelerate the ticks get faster as well.. hard to explain really. Its fairly quiet but it is slightly worrying any ideas what this could be?
Posted: Tue Jan 01, 2013 12:47 pm |
I'd get used to hearing ticking and tapping from a 206 engine bay especially on start up
Posted: Tue Jan 01, 2013 1:08 pm |
tee_lad wrote: |
I'd get used to hearing ticking and tapping from a 206 engine bay especially on start up  |
cant hear on idle, only when its accelerating
Posted: Tue Jan 01, 2013 2:33 pm |
have you checked no rubbish is in your wheels? or around them? could be something fairly simple like that mate.
Posted: Tue Jan 01, 2013 3:06 pm |
i wanna say it sounds like the heads gone lol but touch wood it hasnt
Posted: Tue Jan 01, 2013 3:09 pm |
then check? and it could be driveshaft bearings also
Posted: Tue Jan 01, 2013 3:16 pm |
it could be the tappets making the noise and they may need to be reset
Posted: Tue Jan 01, 2013 4:08 pm |
dan_manu wrote: |
then check? and it could be driveshaft bearings also |
dunno nothing about cars haha just want to know how much it cost to fix
Posted: Tue Jan 01, 2013 4:12 pm |
does your car overheat ? or have oil in the water? if yes then headgasket but it dosent sound to be
- and to no how much its gona cost to fix uv gota no whats wrong lol it could onestly be something as simple as rubbish trapped somewhere
Posted: Tue Jan 01, 2013 4:27 pm |
dan_manu wrote: |
- and to no how much its gona cost to fix uv gota no whats wrong lol it could onestly be something as simple as rubbish trapped somewhere |
no none of the that so i suppose thats good news, yea true ill have a good look round tmoro
Posted: Tue Jan 01, 2013 6:00 pm |
if there's nothing there ask a mechanic to have a look at your driveshaft bearings or doing it yourself by,
- jack you car up
- spin your wheel slowly and listen for the click
- and if you hear it coming from your driveshaft then thats it
- sometimes you can actualy see the bearings hop so watch the bearings also
Posted: Thu Jan 03, 2013 3:32 am |
Its just the sound of the drive belt,alternator,etc.....its completely normal and just another case of someone looking too hard to find a problem and a post.
Posted: Thu Jan 03, 2013 6:53 am |
i'd say its the infamous ew10 tick, they are known for it at the tappets (a search should bring up some info on it). mine does/did it when warm and revved. from what i recall its nothing major to worry about unless it gets dramatically worse
Posted: Wed Jan 09, 2013 2:29 pm |
will get the tappets looked at, nothing to do with the drive belt. and as said it is only heard when accelerating the engine is sweet on idle
Posted: Wed Jan 09, 2013 3:35 pm |
206gti_chris wrote: |
will get the tappets looked at, nothing to do with the drive belt. and as said it is only heard when accelerating the engine is sweet on idle |
If it was the tappets/hydraulic lifters it would happen at idle too.
