Online Now [280]:
Visitors: 279
Today: 28259
Total: 142650090
Forums › The Car › 206 Talk › what are the best bulbs to fit frontend ?
donnypaul81
PostPosted: Tue Jan 01, 2013 5:25 pm Up
Well th head lights on the car are shocking I can barely see any thing on a night can any body suggest to me what to replace them with I'm not bothered about hid conversion and I don't want the blue tint bulbs either I have the clear lens type if it helps on a 03 plate and what bulb code are they as I'm not sure with out taking g them out so please tell me what they are and I'll order a full set main beam side light indicators etc also have the grand tourisme bumpers what bulbs fit the fog lights these are clear as well and 1 has blow so looking at changing every thing in 1 go cheers
PostPosted: Tue Jan 01, 2013 5:26 pm Up
H7 headlights and H1 in the fogs.
PostPosted: Tue Jan 01, 2013 5:29 pm Up
Osram or Philips seem the preferred choice for standard crystals.
donnypaul81
PostPosted: Tue Jan 01, 2013 5:35 pm Up
Halfords have an offer on there own bulbs but seemed a littlbit expensive £29 for 2 bulbs. Would you suggest the halogen type?
PostPosted: Tue Jan 01, 2013 5:52 pm Up
ECP have Osram Nightbreaker+ @ £12.49 (twin pack) and Philips Visionplus @£15.90 (twin pack).
Halogen are the recommended although mtec (Xenon) are quite cheap. 55w power draw and 100w output (road legal) and are £10.99. If you just put 100w bulbs in, then they aren't road legal and could damage the wiring.
donnypaul81
PostPosted: Tue Jan 01, 2013 6:01 pm Up
So basically I need 4 x h1 2 x h2 and 2 x 501 bulbs the indicator bulbs can stay same as there new any way. And I'll order the Phillips halogen as this in are probs 50p bulbs off market stall lol
PostPosted: Tue Jan 01, 2013 6:12 pm Up
You need 2 x H1 (foglights) and 4 x H7 (dipped and main beam)
501 are the sidelights and H2 aren't used on a 206 unless you have aftermarket lights.
It should be stamped/printed on top of the headlamp unit which bulbs are fitted. Just open the bonnet and have a look if you're unsure.
Don't know why you're replacing the fog light bulbs unless they are blown. Unless you're one of the idiots that drives around with them turned on in clear visibility, new bulbs won't make a difference to how much light they put out in normal driving conditions. Just replace the dipped beam and throw the main beam ones in if you do a lot of driving on unlit roads.
donnypaul81
PostPosted: Tue Jan 01, 2013 6:21 pm Up
Got numbers mixed up tired and that good job you said or I'd be ordering wrong bulbs like other night I thought I got a bargain on eBay bid on this game and it wasn't what I thought it was and my son said he already got it lmao
20Drift
PostPosted: Tue Jan 01, 2013 7:26 pm Up
I think we got the message Wink
PostPosted: Wed Jan 02, 2013 1:15 pm Up
Do you have a Crystal Headlights fitted,or do you have Angel Eyes (after market ones),if the Crystals are fitted,then I recommend that you use,OSRAM Night Breaker Plus,it's a A++ :D,I have them on mine
anton1989
PostPosted: Wed Jan 02, 2013 1:50 pm Up
Trade Rating: +16
206HdiGti
PostPosted: Wed Jan 02, 2013 2:02 pm Up
I recently fitted Osram Nightbreakers to mine and they are awesome and I have standard front lights
donnypaul81
PostPosted: Wed Jan 02, 2013 2:08 pm Up
Cheers ordered the night breakers
PostPosted: Wed Jan 02, 2013 3:16 pm Up
Thumbs Up Rock Onnnnn..
Ali13
PostPosted: Wed Jan 02, 2013 4:18 pm Up
glad you asked this but i really wanted to change mine last year there pathetic the standard lights
