Latest: tbafonso
Overall: 17130
Online Now [167]:
Visitors: 166
Today: 61373
Total: 102469596
Forums › The Car › 206 Problems › Battery keeps running after key removed
Kayles
PostPosted: Tue Jan 01, 2013 4:43 pm Up
Somebody help me ! My HDi pug is broken ! When I turn my car off everything goes off but then my battery light/radio and interior light come back on.. Anyone know what's going on or is she just coming to life?
PostPosted: Tue Jan 01, 2013 5:02 pm Up
Have you got an aftermarket radio fitted or messed around with any of the electrics?
At the moment it seems to point towards a knackered ignition switch.
Kayles
PostPosted: Wed Jan 02, 2013 6:20 am Up
No everything's standard and haven't touched any electrics
PostPosted: Wed Jan 02, 2013 12:23 pm Up
try to disconnect the ignition switch plug,and see if this problem ends or not,if it ends,then you need a new ignition barrel
vanepico
PostPosted: Fri Jan 04, 2013 9:41 am Up
did you short any wires out in the radio? Check one of the fuses this happened to me when i shorted the tel mute on my radio to the chassis of the radio, something went pop, replaced the fuse and it was fine!
vanepico
PostPosted: Fri Jan 04, 2013 9:42 am Up
i mean a fuse under the steering wheel
