Latest: sparrowdclxvi
Overall: 17139
Online Now [116]:
Visitors: 115
Today: 10310
Total: 113016005
Forums › The Car › 206 Problems › Driveshaft Issue
Driveshaft Issue
Go to page Previous  1, 2
novatron1_2
PostPosted: Wed Jan 02, 2013 6:45 pm Up
bezford wrote:
Is it not possible to change the hub???infact id be tempted to goto a scrappy and remove the entire assembly...hub.shaft.disc.nut.susspension arm...and refit the full assembly onto yours...it shouldnt be too expensive and for a bit extra they will take the assembly off for you...but make sure its gonna fit on the gearbox end...
If u havnt got the gearbox back from garage yet id get it to check the scrappied assembly and to sell the box seen as there's nothing wrong with it.
+1 on the above
206 1.9D, 210,000 now dead following failed submarine experiment (flood)
Page 2 of 2
