Latest: Stu-mill
Overall: 17131
Online Now [53]:
Visitors: 52
Today: 77706
Total: 104886517
Forums › The Car › 206 Problems › heating
heating
bluexsi
PostPosted: Thu Mar 03, 2011 2:11 pm Up
the heating in my 51 plate xsi has stopped working. its got a/c and when the blower is off it works but when you try to put the blower on it cuts off the rear demister still works aswell. iv takin it to a garage and the said it could be something to do with the ignition barrel is this common thanks?
2001 xsi
beat275
PostPosted: Thu Mar 03, 2011 2:16 pm Up
i think its the head gasket
peugeot 206
bluexsi
PostPosted: Thu Mar 03, 2011 2:22 pm Up
if its the head gasket it would be blowing out cold air its not working at all tahts why a thought it was electrical
2001 xsi
206gti_chris
PostPosted: Tue Jan 01, 2013 3:57 pm Up
lol
bezford
PostPosted: Wed Jan 02, 2013 7:44 pm Up
Sounds like overload cutting it out???il check out some papets and respond on thursday evenin...doesnt sound like head gasket but it might be worth getting a gas in coolant test at a garage...about£35 unless u can blag them and wave the full head job under there nose so they feel sure its head fault then u say just to confirm before u do it...but be sure they show u the liquid in the test as its mixed and rested...if u r unfamiliar with this test its just a big suction tube with a test solution in it and they run the car and suck coolant from radiator/expansion tank and the two liquids mix and if engine gasses are present it turns blue or green...if it changes colour like that u need head doing.
R.HYDE
bezford
PostPosted: Thu Jan 03, 2013 4:49 am Up
Why not too give advice when half asleep???????sorry.....
R.HYDE
