Online Now [542]:
Visitors: 541
Today: 91044
Total: 146793672
Forums › The Car › 206 Problems › Ticking engine noise
206gti_chris
PostPosted: Tue Jan 01, 2013 12:54 pm Up
Noticed today a strange noise from the engine, it is only heard when i accelerate from 2k + its like a 'ticking noise' as you accelerate the ticks get faster as well.. hard to explain really. Its fairly quiet but it is slightly worrying Neutral any ideas what this could be?
tee_lad
PostPosted: Tue Jan 01, 2013 1:47 pm Up
I'd get used to hearing ticking and tapping from a 206 engine bay especially on start up Sad
206gti_chris
PostPosted: Tue Jan 01, 2013 2:08 pm Up
cant hear on idle, only when its accelerating
dan_manu
PostPosted: Tue Jan 01, 2013 3:33 pm Up
have you checked no rubbish is in your wheels? or around them? could be something fairly simple like that mate.
206gti_chris
PostPosted: Tue Jan 01, 2013 4:06 pm Up
i wanna say it sounds like the heads gone lol but touch wood it hasnt
dan_manu
PostPosted: Tue Jan 01, 2013 4:09 pm Up
then check? and it could be driveshaft bearings also
jk206
PostPosted: Tue Jan 01, 2013 4:16 pm Up
it could be the tappets making the noise and they may need to be reset
206gti_chris
PostPosted: Tue Jan 01, 2013 5:08 pm Up
dunno nothing about cars haha just want to know how much it cost to fix
dan_manu
PostPosted: Tue Jan 01, 2013 5:12 pm Up
does your car overheat ? or have oil in the water? if yes then headgasket but it dosent sound to be
- and to no how much its gona cost to fix uv gota no whats wrong lol it could onestly be something as simple as rubbish trapped somewhere
206gti_chris
PostPosted: Tue Jan 01, 2013 5:27 pm Up
no none of the that so i suppose thats good news, yea true ill have a good look round tmoro
dan_manu
PostPosted: Tue Jan 01, 2013 7:00 pm Up
if there's nothing there ask a mechanic to have a look at your driveshaft bearings or doing it yourself by,
- jack you car up
- spin your wheel slowly and listen for the click
- and if you hear it coming from your driveshaft then thats it
- sometimes you can actualy see the bearings hop so watch the bearings also
bezford
PostPosted: Thu Jan 03, 2013 4:32 am Up
Its just the sound of the drive belt,alternator,etc.....its completely normal and just another case of someone looking too hard to find a problem and a post.
R.HYDE
Indigo_GTI
PostPosted: Thu Jan 03, 2013 7:53 am Up
i'd say its the infamous ew10 tick, they are known for it at the tappets (a search should bring up some info on it). mine does/did it when warm and revved. from what i recall its nothing major to worry about unless it gets dramatically worse
206gti_chris
PostPosted: Wed Jan 09, 2013 3:29 pm Up
will get the tappets looked at, nothing to do with the drive belt. and as said it is only heard when accelerating the engine is sweet on idle
Big_Rich180
PostPosted: Wed Jan 09, 2013 4:35 pm Up
If it was the tappets/hydraulic lifters it would happen at idle too.
