Latest: Beduff1977
Overall: 17134
Online Now [1353]:
Visitors: 1352
Today: 33507
Total: 107138956
Forums › The Car › 206 Problems › side airbag
side airbag
Go to page Previous  1, 2
Mattie-RS
PostPosted: Fri Jan 04, 2013 7:25 am Up
Have you deployed a airbag and replaced it?
Not sure but doesn't the airbag Ecu need to be reprogrammed by pug once it has deployed a bag
Big_Rich180
PostPosted: Fri Jan 04, 2013 7:38 am Up
I'm pretty sure Andy had to have his re-programmed or replaced when his side airbag went off, I forget what it cost now though.
PostPosted: Fri Jan 04, 2013 9:55 am Up
Just been out and checked my airbag ECU for it's configuration settings. I only have driver and passenger airbags. It might be different for a pre plex, but this could give you a reference point to start at.
sheerness
PostPosted: Sat Jan 05, 2013 11:31 am Up
hay guys ok I have spent most of today trying to sort this problem out, I had this error with the seat belts pretension so I went to the scrap yard today and got 2 of them and connected them both and still have the same problem, I am pulling my hair out with it all. I have turned on the car with them disconnected and the airbag light start to flash, so quickly reconnected them, I am pretty sure that the are no connections on the thing that you put your seat belt in to, Arrrrrhhhhhh I don't fancy all of Sunday trying to do all this again and get no result! I am sure that the airbag have never gone off so I can rule that out....
again all and more advise is needed please guys,
I need to get to the bottom of this.
Kind Regards
Dom.....
bezford
PostPosted: Sat Jan 05, 2013 3:06 pm Up
Doesnt anybody have a handbook for the car???mine never came with one unfortunately...
R.HYDE
sheerness
PostPosted: Sat Jan 05, 2013 3:14 pm Up
no I don't have one!..
Do you know a site of where could just buy one and download it?...
KR
Dom.....
PostPosted: Sat Jan 05, 2013 4:42 pm Up
KR
Dom.....
public.servicebox.peug...m/dtt/ddb/
Have you checked the configuration of the airbag ECU yet?
Check on service box for the characteristics of the car, basically what it left the factory with and it should tell you which airbags were fitted.
sheerness
PostPosted: Sun Jan 06, 2013 9:17 am Up
hi guys still been trying to get this problem sorted, also a few errors that we are coming across, i have a few pics that i could do with a little help from someone?
also there is a screen to tell us that there is no reply from the ECU for some unknown reason ;(
bezford
PostPosted: Sun Jan 06, 2013 9:34 am Up
Ive never used the pp yet so sorry cant help.
R.HYDE
PostPosted: Sun Jan 06, 2013 10:06 am Up
On your second screen shot, when you hit "Enter" what fault information did it give you?
Go into the Airbag ECU configuration from the global test, and check to see what is and isn't activated. Check on servicebox as to what is fitted on the car. Activate or deactivate as required and it should sort out the dashlight. If needs be, just set everything to "absent". Set each item as "present" in turn and see which one illuminates the light. Just leave that as absent and you should be sorted and be able to pinpoint the area of the fault.
Mattie-RS
PostPosted: Sun Jan 06, 2013 10:32 am Up
With you replacing a part I think you may need pug to reconfigure the airbag ecu.
sheerness
PostPosted: Sun Jan 06, 2013 1:27 pm Up
hi again I have got back in from the car, i am going to try and put in order of the screen grab of each part i have been trying to do.
Global Test
then airbag ecu
then configuration
and keep getting this page
again i am lost
what to do now?
KR
Dom.....
Page 2 of 2
