Latest: jackrox1992
Overall: 17186
Online Now [389]:
Visitors: 388
Today: 58567
Total: 148437767
Forums › The Car › 206 Problems › Starting off from standstill problem
x-jonny-x
PostPosted: Thu Jan 10, 2013 3:15 am Up
Hi ive got a little problem with my 206.
When im at a standstill waiting to go at say some traffic lights, when i go to set off the cars power seems to fall and i have to put loads of revs in to stop it from stalling.
To avoid this at the moment i have to set off at 2.5 - 3k.
Surely this isnt normal? (This is my first 206, i usually have german cars)
Thanks for any replys in advance
PostPosted: Thu Jan 10, 2013 3:51 am Up
This can be fixed by cleaning the Throttle Body,read this thread below:
Cleaning Throttle Body
x-jonny-x
PostPosted: Thu Jan 10, 2013 4:59 am Up
Yeah i read this earlier, looks like i'll be doing that at the weekend then. Thanks
PostPosted: Thu Jan 10, 2013 5:50 am Up
You are most welcome :),if you need any help,let me know Smile
PostPosted: Thu Jan 10, 2013 6:21 am Up
What happens of you put your foot down when driving normally? If the revs rise quickly but the speed is slow to catch up it could be a slipping clutch.
x-jonny-x
PostPosted: Thu Jan 10, 2013 8:17 am Up
Its fine when moving its just on start off
PostPosted: Thu Jan 10, 2013 1:04 pm Up
So at least you'll be used to having problems then.
vanepico
PostPosted: Thu Jan 10, 2013 1:55 pm Up
how does getting a bit of soot off the butterfly make it work better? I don't understand :s
x-jonny-x
PostPosted: Fri Jan 11, 2013 3:24 am Up
Ive actually never had problems with the actual running of my cars before. Had loads of eml light to sort out in the past but they never affected the performance
paulspug
PostPosted: Fri Jan 11, 2013 8:52 am Up
bottom engine mount worn?
