Latest: cogeim7
Overall: 17185
Online Now [1588]:
Visitors: 1587
Today: 25365
Total: 147341522
Forums › The Car › 206 Problems › 206 Climate control problems
whittick88
PostPosted: Thu Jan 10, 2013 5:41 am Up
Hi,
I have been having a couple of problems with the climate control in my 206 (V reg Roland Garros)...
I switch the car on and turn on the heater (AC has no gas as recently changed the pump and didn't bother getting it regassed due to these issues), generally nothing will happen and ill have to wipe the screen and set off on my way.
However about 10 minutes into the journey the CC will take on a mind of its own and go from refusing to blow any air to setting itself to max and going nuts.
I've always just put up with this but its getting to be a bit of a problem in the winter months now and would really like to get it sorted. Recently it seems as if the bulb in my clock/radio display and CC display pannel have gone too, not sure if these are related but I would assume not.
My question is has anyone had any issues similar to this? Could it be something like the resistor needs replacing?
Any help would be much appreciated.
Thanks,
Ben
PostPosted: Thu Jan 10, 2013 6:17 am Up
well i believe that you have to refill your A/C system with gas,because when you turn the CC on,with the mode for front windshield,that compressor will kick in to remove the condensation you got inside,most new models have got the same process,like VAG and Hyundai,but you can turn the compressor off and use the ECO mode like this:
about the bulbs,you need to replace it,because they get faulty with time.
whittick88
PostPosted: Fri Jan 11, 2013 9:27 am Up
Hi Timon thanks for the reply, this is when using the climate control on 'eco' I don't use the A/C as I know there's no gas. It's a really weird behaviour as when I turn the car on and switch the CC to 'eco' nothing happens, it's as if I've not turned the heater on at all. then about 10 minutes into the journey it will decide to work, switch the fan icon to max and I need to lower it to 1/2-1 blade after which point it seems to work fine.
I'm watching a new climate control faceplate on ebay that I'm considering buying but not convinced this will fix the issue. Has anyone else experienced turning the fan (not AC) on, nothing happening, then 10 mins later it switching to max and working as if there are no issues?
Thanks,
Ben
PostPosted: Fri Jan 11, 2013 11:46 am Up
eco, MAY be an automatic mode.
It could be measuring the temp inside the car and the fan doesn't blow until the engine is up to temperature, or some similar automated control.
PostPosted: Fri Jan 11, 2013 12:17 pm Up
Quite simply it needs a new fan. air con gas is nothing to do with it. I've got no wiring, pipes, gas or anything on my GTi and the fan/heater still works as it always did.
Ltech
PostPosted: Sat Jan 31, 2015 3:25 pm Up
Hi can anyone help me, my climate is the same as the picture above, but the lights don't work behind the buttons but they are working on the display! Can these bulbs be changed or is it a seal unit?
MrWhite
PostPosted: Sun Feb 01, 2015 11:17 am Up
yes they can and strangely enough i did it the other day in mine. im not sure there's a Tutorial here but i can do one if you cant find one on the forum
My 206 Project Thread
