Latest: sparrowdclxvi
Overall: 17139
Online Now [182]:
Visitors: 181
Today: 27294
Total: 113475452
Forums › The Car › 206 Talk › GTi 180 brake calliper torx bit?
Junglingo
PostPosted: Fri Jan 11, 2013 3:24 pm Up
I need a torx bit to take the front callipers off a 180. Can anyone tell me the size I need? Thank you!
GTi 180 - Scorpion Exhaust
richpowell91
PostPosted: Fri Jan 11, 2013 3:40 pm Up
T55 if i remember correctly.
broadblaster
PostPosted: Fri Jan 11, 2013 4:12 pm Up
hey another 180 in hants where abouts are you mate ?????
on a back road playing
Junglingo
PostPosted: Fri Jan 11, 2013 5:50 pm Up
Okay thanks. I'm based in Fleet. But at Uni in Hull at the moment
LiamGTi180
PostPosted: Fri Jan 11, 2013 6:58 pm Up
Yeah definately T55. Just done it. They are a pain in the a**e to get off
nellyhaggis
PostPosted: Fri Jan 11, 2013 7:19 pm Up
Be careful as they are not torque bolts if they are the same as mine.
Tou will need something called a ribe tool to get them off.
It's very similar to torque which might do the job but mine were on solid and I stripped the centre with a torque bit.
Best of luck.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
Junglingo
PostPosted: Sat Jan 12, 2013 6:54 pm Up
oh dear. well i went out and bought a T55 and it seems to fit snug. going to attempt the discs tomorrow. not heard of ribe at all.
nellyhaggis
PostPosted: Sun Jan 13, 2013 3:41 am Up
It should do it if they are not on solid.
Failing that I ended up hammering a socket onto the bolt and got new ones from pig. I think they were a couple of quid each.
Junglingo
PostPosted: Sun Jan 13, 2013 7:21 am Up
Yep they are stuck on tight. Can't shift them as hard to get the leverage. Impact hammer will hopefully help.
Junglingo
PostPosted: Sun Jan 13, 2013 12:04 pm Up
Finally got the buggers off with a breaker bar and brute force. had to dremel a couple of disc alignment screws and turn them into flathead screws to get them off
