Posted: Fri Jan 11, 2013 2:24 pm |
I need a torx bit to take the front callipers off a 180. Can anyone tell me the size I need? Thank you!
| GTi 180 - Scorpion Exhaust | |
Posted: Fri Jan 11, 2013 2:40 pm |
T55 if i remember correctly.
Posted: Fri Jan 11, 2013 3:12 pm |
hey another 180 in hants where abouts are you mate ?????
Posted: Fri Jan 11, 2013 4:50 pm |
Okay thanks. I'm based in Fleet. But at Uni in Hull at the moment
Posted: Fri Jan 11, 2013 5:58 pm |
Yeah definately T55. Just done it. They are a pain in the a**e to get off
Posted: Fri Jan 11, 2013 6:19 pm |
Be careful as they are not torque bolts if they are the same as mine.
Tou will need something called a ribe tool to get them off.
It's very similar to torque which might do the job but mine were on solid and I stripped the centre with a torque bit.
Best of luck.
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Sat Jan 12, 2013 5:54 pm |
oh dear. well i went out and bought a T55 and it seems to fit snug. going to attempt the discs tomorrow. not heard of ribe at all.
Posted: Sun Jan 13, 2013 2:41 am |
It should do it if they are not on solid.
Failing that I ended up hammering a socket onto the bolt and got new ones from pig. I think they were a couple of quid each.
Posted: Sun Jan 13, 2013 6:21 am |
Yep they are stuck on tight. Can't shift them as hard to get the leverage. Impact hammer will hopefully help.
Posted: Sun Jan 13, 2013 11:04 am |
Finally got the buggers off with a breaker bar and brute force. had to dremel a couple of disc alignment screws and turn them into flathead screws to get them off
