Online Now [683]:
Visitors: 682
Today: 152489
Total: 145262734
Forums › The Car › 206 Problems › Idle concern 206 gti
Go to page 1, 2, 3  Next
Jordy6969
PostPosted: Sun Jan 13, 2013 10:07 am Up
Just purchased a 206 gti 140 bhp V reg and I have a concern regarding the idle.
I was driving in london last night and on standstill the idle sometimes dropped to just below 800rpm, felt like it may cut out, however it didn't.
I don't know if this makes any difference to what it could be... but when I put the A/C on, straight away it went back to normal 900/1000rpm
Any help would be much appreciated
Cheers.
PostPosted: Sun Jan 13, 2013 10:14 am Up
Clean the stepper motor and airway.
www.206info.co.uk/Foru.../t=72.html
DanT
PostPosted: Sun Jan 13, 2013 10:25 am Up
As mentioned idle stepper motor would benefit from a clean, i'd be inclined to remove the whole throttle body myself and give it a good going over but you might find thats not necessary.
Jordy6969
PostPosted: Sun Jan 13, 2013 10:41 am Up
How about cleaning the idle control valve, would that be necessary
PostPosted: Sun Jan 13, 2013 11:26 am Up
Idle control valve
Idle stepper motor
Same thing different name.
PostPosted: Sun Jan 13, 2013 1:37 pm Up
Isnt that the normal idle range? Is on my gti anyway, unless your engine is struggling to tick over?
PostPosted: Sun Jan 13, 2013 3:30 pm Up
Take a look at this,might give you a better explaning on what to do
www.206info.co.uk/Foru...46523.html
Jordy6969
PostPosted: Mon Jan 14, 2013 6:31 am Up
I don't think the idle is meant to be at just below 800rpm pal, engine struggles to stay on when it happens. However put the A/C on and it's fine again
Jordy6969
PostPosted: Mon Jan 14, 2013 6:32 am Up
Cheers Timon will use that one. Pictures always help
Jordy6969
PostPosted: Mon Jan 14, 2013 11:33 am Up
Used both the guides, couldn't find the map sensor on my engine however. Will update on results of the new year clean
PostPosted: Mon Jan 14, 2013 11:56 am Up
Can't help with picture of your map sensor location as I only have access to 1.4 8V at the moment.
Jordy6969
PostPosted: Mon Jan 14, 2013 12:54 pm Up
Can you not explain it?
PostPosted: Mon Jan 14, 2013 1:16 pm Up
I could if I had a quick look at the car first and I am still at work. It's a long time since I have worked on a 1.6 and the MAP sensor may be in a different place than the 1.4 I will have access to.
Hopefully someone here will explain where the 1.6 MAP sensor is located.
Jordy6969
PostPosted: Mon Jan 14, 2013 2:57 pm Up
I haven't got a 1.6, got a gti pal
PostPosted: Mon Jan 14, 2013 4:47 pm Up
Sorry, but either way it will be different to a 1.4 8V.
Page 1 of 3
