Online Now [304]:
Visitors: 303
Today: 65433
Total: 105959423
Forums › The Car › 206 Problems › CD PLAYER
CD PLAYER
lisa206
PostPosted: Sun Jan 13, 2013 11:17 am Up
I have a GTI with the standard CD player in well tape player. I got the stereo out my XSI to replace the one in my GTI. It worked perfect in my XSI but for some reason it won't work in the GTI. I have checked all the wires and fuses these are fine. I have even tried another CD player in the car , this won't work either. Can any one help ??
LISA 206 180
iainlovatt
PostPosted: Sun Jan 13, 2013 11:23 am Up
damaged wiring harness? Thats what it was with me.
(My Garage)
lisa206
PostPosted: Sun Jan 13, 2013 12:17 pm Up
I cant find the switched ignition live , anyone know where this is
LISA 206 180
gazza82
PostPosted: Sun Jan 13, 2013 2:28 pm Up
Are the two cars the same electronics systems? Non-Mux or Mux?
lisa206
PostPosted: Sun Jan 13, 2013 2:44 pm Up
im not sure how would i know this?
LISA 206 180
gazza82
PostPosted: Mon Jan 14, 2013 5:12 pm Up
Is the steering column radio stalk a long thin one or a short shubby one?
Long and thin is pre-mux, short and shubby is multiplex. The radio has to come from the same type.
So what is the GTI's stalk and what was the XSi??
lisa206
PostPosted: Tue Jan 15, 2013 4:22 pm Up
ahh the GTI one is short and XSI one is long thin.
LISA 206 180
gazza82
PostPosted: Fri Jan 18, 2013 1:54 pm Up
Can't swap them then ... but I guess you already already worked that out.
Rob206
PostPosted: Fri Jan 18, 2013 2:05 pm Up
learn some thing new every day lol
lisa206
PostPosted: Fri Jan 18, 2013 2:17 pm Up
why cant i swap them ?
LISA 206 180
PostPosted: Fri Jan 18, 2013 2:20 pm Up
That's crazy design. I know mux/BSI system is tricky but this is mad. What about after market systems? Really no way around this?
broadblaster
PostPosted: Fri Jan 18, 2013 3:03 pm Up
yes you can fit aftermarket no probs but not plex and non plex set ups also the plex ones are coded to the ecu for each car so try fitting a plex one into another plex car and it will just bleep at you every 3 seconds.
on a back road playing
PostPosted: Fri Jan 18, 2013 3:07 pm Up
Thanks for clarifying.
broadblaster
PostPosted: Fri Jan 18, 2013 3:10 pm Up
i'm sure somebody out there can recode them but not sure if its really worth the hassle as aftermarket ones are so cheap nowdays and better than the standerd ones.
PostPosted: Fri Jan 18, 2013 4:48 pm Up
With pp you can recode, but I don't know about non mux to mux.
