Latest: airmastertapes
Overall: 17133
Online Now [952]:
Visitors: 951
Today: 130726
Total: 106842531
Forums › The Car › 206 Problems › Accessing the fuel lines!
Go to page Previous  1, 2
PostPosted: Mon Jan 21, 2013 11:19 am Up
Back seats, then the plastic cover and there might be 3 rivets to drill out...
Jordy6969
PostPosted: Mon Jan 21, 2013 1:03 pm Up
Can you tell me which line on top of the petrol tank is the one I'm talking about so I know which one to pull out?
PostPosted: Mon Jan 21, 2013 1:12 pm Up
Pull the one which is loosest!
Jordy6969
PostPosted: Mon Jan 21, 2013 1:18 pm Up
Ah okay! Trouble is they're both loose because its all disconnected, il have to figure it out.
Cheers buddy
Jordy6969
PostPosted: Mon Jan 21, 2013 1:21 pm Up
I need the part number, anyone know how to find this?
PostPosted: Mon Jan 21, 2013 1:28 pm Up
I suspect it's part 8 in this diagram.
spike_202
PostPosted: Mon Jan 21, 2013 1:36 pm Up
How did you break it off can I ask? we're you using pliers or just pulled a bit to hard? Just so every one can learn from this.
**spike's project**
TEAM:+200bhp
Jordy6969
PostPosted: Mon Jan 21, 2013 2:04 pm Up
I broke it off by failing to disconnect the hose from the fuel filter before trying to remove it. It's been a right a******e!
Edward, does that diagram show the part number?
Jordy6969
PostPosted: Tue Jan 22, 2013 9:59 am Up
Replaced the part today from peugeot, it cost £10.90
Page 2 of 2
