Latest: Kifi69
Overall: 17183
Online Now [493]:
Visitors: 492
Today: 65378
Total: 144356936
Forums › The Car › 206 Problems › stereo stopped working
bambam90
PostPosted: Tue Jan 22, 2013 3:14 pm Up
Hi I recenty fitted some 6x9s in my mates mk4 ibiza it was fine for about an hour then the headunit stopped all together,
We put another unit in, it iluminated with the lights but still wudnt work,
We checked all fuses and also unplugged wires to check if they were shothing it but still nothing HELP!!
P.s tryed the ibiza forum not gettin much back so I fort id ask you guys
ukskater01
PostPosted: Tue Jan 22, 2013 3:29 pm Up
If you disconnect the 6x9's will the stereo work? How have you got the signal for the 6x9's?
bambam90
PostPosted: Tue Jan 22, 2013 3:32 pm Up
Hi o still duznt work and just bridged them to the front ones like I always have
PostPosted: Tue Jan 22, 2013 4:18 pm Up
Series or parallel. Do we wait for smoke from the head unit?
broadblaster
PostPosted: Tue Jan 22, 2013 4:37 pm Up
so you don't think that maybe your overloading the H/U by runing the 6x9's and the fronts togeather then ??.
why do you not just run new cable to the rears from the H/U.
on a back road playing
bambam90
PostPosted: Tue Jan 22, 2013 4:39 pm Up
Come agen lol im not a very tchnical kinda guy lol
broadblaster
PostPosted: Tue Jan 22, 2013 4:43 pm Up
ok so why do you not run new speaker cable from the headunit to the 6x9's, i think that you are overloading the headunit by trying to run 2 sets of speakers from one power source I:E the fronts speakers.
bambam90
PostPosted: Tue Jan 22, 2013 4:53 pm Up
Fair coment but I havealways done this its how my car is running now, just need to no wot cud be rong with the car a d get the stereo back
broadblaster
PostPosted: Tue Jan 22, 2013 4:56 pm Up
well by overloading it you have maybe burnt it out or it may have a thermal cut out to protect it but i doubt that if its stopped working even after its cooled back down.
bambam90
PostPosted: Tue Jan 22, 2013 5:29 pm Up
Yes quite clearly it blown the origional one works .........oops
bambam90
PostPosted: Tue Jan 22, 2013 5:54 pm Up
Mmmmmmmm works in my 206 :s
PostPosted: Tue Jan 22, 2013 6:39 pm Up
Most but not all stereos have over load protection. I suggest that this doesn't and at some point while fitting the rear speakers and with head unit power on you have shorted the speaker wires together (or let the + speaker cable touch earth) and blown the rear output channels of the head unit.
If this unit does not have overload protection and you have now wired the speakers in parallel (I suspect it is rather than series connection) then there is a high(ish) risk that at full volume you will now blow the front output.
It may not blow straight away but high sounds for sustained periods of time may eventually cause failure.
You should be able to check on the unit or manual to see what impedance speakers it is designed for. I suspect it will be either 4, 6 or 8 ohm. If it is rated for 4 - 8 ohm you should be OK. If it is only 8 ohm you are pushing your luck.
