Latest: tebas93089
Overall: 17179
Online Now [92]:
Visitors: 91
Today: 2481
Total: 138149640
Forums › The Car › 206 Problems › MAP Sensor- I'm worried!
Go to page Previous  1, 2
Deckchair5
PostPosted: Thu Sep 20, 2012 1:35 am Up
My issue is only when starting, and only when cold and maybe rough idle just after it starts. Warm starts are alright and no cutting out.
Would this still point to a crank sensor?
Absolutely. The ECU needs to detect engine is rotating and going at minimum rpm before it will allow fuel and ignition. If it's missing engine pulses then it thinks it hasn't reached that minimum rpm and car isn't allowed to start. It doesn't fire up a fault code because it doesn't detect there's anything wrong with the crank sensor because there isn't anything wrong with its circuit. It's just waiting for the engine rpm to come up and waiting and waiting Smile
When everything is heated on a warm engine and flywheel is expanded then it's picking up the pulses no problem and the engine is allowed to start as normal and runs fine
Sensor position is in line with the flywheel
BigWal
PostPosted: Thu Sep 20, 2012 5:11 am Up
Great- crank sensor it is. I'll post back with the results. Thanks for the assistance
2002 206 GTi
1999 206 GTi
2005 206 GTi 180
BigWal
PostPosted: Sun Dec 02, 2012 4:39 am Up
Ok so got myself a new crank sensor, and removed the old one that was absolutely caked in gunk.
Wit high hopes I started it cold this morning but to no avail- still a hesitant start and the revs only stayed at 1200 for 5 or so seconds before dropping to 1000. When I started it it again very briefly flashed up anti pollution fault but still the engine light is not on. I'm starting to believe it could be coil pack related, or if not pressure regulator.
Any other thoughts?
2002 206 GTi
1999 206 GTi
2005 206 GTi 180
PostPosted: Sun Dec 02, 2012 5:17 am Up
That's the best thing I've heard in ages.
The flywheel is a solid lump of steel which won't expand in the slightest and it doesn't even get that hot!
bezford
PostPosted: Tue Dec 04, 2012 8:56 am Up
Do u get any extra drop off of revs if u turn electrics on at this stage???poss.battery/charging circuit fault???turn on lites a.c.radio etc when cranking or experiencing the problem to check...
R.HYDE
BigWal
PostPosted: Tue Dec 04, 2012 8:32 pm Up
No- and I have occassionally taken the battery out to trickle charge it, so the battery is still strong after 2 years.
I am at my wits end with this thing- no codes don't help obviously. One thing I was thinking about is that it has 135k kms on it (75k miles) and I certainly haven't had the injectors cleaned since I've had it for 6 years.
Any views on if getting the injectors cleaned would help a hesitant start?
It very occasionally misfires after it has been started...
2002 206 GTi
1999 206 GTi
2005 206 GTi 180
bezford
PostPosted: Wed Dec 05, 2012 9:18 am Up
Possibly but dirty injectors would be more a diesel fault i think...i will study the haynes ive just got.
R.HYDE
BigWal
PostPosted: Wed Dec 05, 2012 8:26 pm Up
hey bezford, thanks for taking the time. I put a bottle of injector cleaner through a few days ago and it really has not made a difference, so I can safely stop thinking about that.
One other thing I was thinking about is the fuel pressure. I said before that I think the regulator is in the actual fuel pump, unlike a sperate one for diesels. The only problem with this car is a cold start, and VERY occasionally it flashes up (by half a second) APF and then dissappears.
Would I be right in thinking that it flashes APF (anti poll.) due to the fuel pressure being low, and then once it cranks and starts the pressure returns to normal? The EML has NEVER flashed nor remained on...
2002 206 GTi
1999 206 GTi
2005 206 GTi 180
Daz2402
PostPosted: Tue Jan 22, 2013 6:26 pm Up
Hi guys I'm bit new to pug scene been a jap man but cheap 206 gti came up just as I lost heart In my old civic. Anyways I've rebuild the engine on my drive and kinda have a fault I can't place gut telling me map sensor? When I start up its powerless under 2k Sad and tries to die? Sorry for thread jacking!
Your probably sounds a lot like my mates turned out to be faulty O2 sensor!
Oh forgot to say my gti is a 1999 pre multi plex I believe?!
Thanks info is u can Smile
Page 2 of 2
