Online Now [165]:
Visitors: 164
Today: 14432
Total: 143212644
Forums › The Car › Solved 206 Problems › blower problem
blower problem
g24538539
PostPosted: Wed Jan 23, 2013 11:41 am Up
Can anyone help solve this problem . My wifes car heater would only work when on full then it gave up and died . After searching I found that the resistor switch has blown . I replaced it and it worked for an hour or so then stopped again . . I didn't replace the cabin filter . Could this cause the resistor to over heat or is it something more . ? Any help would be greatful . Thanks george.
PostPosted: Wed Jan 23, 2013 12:50 pm Up
try to take the cabin filter out,because if it's blocked it can make the blower motor run with load,which can make it stop so that it don't get burnt.
