Latest: Beduff1977
Overall: 17134
Online Now [817]:
Visitors: 816
Today: 110321
Total: 108045515
Forums › The Car › 206 Talk › 1.4 8v Service
1.4 8v Service
Go to page Previous  1, 2
olly
PostPosted: Fri Jan 25, 2013 5:33 am Up
I just did a full service to my girls 2001 1.4 8v this week,all parts from ecp,including oil filter paper type,air filter,Bosch plugs,pollen filter,5litre 10w40 semi synth oil,5 litre red concentrate antifreeze,and engine flush for £49,this is online order only with 25% discount tho. Olly
bcfc
Austin
PostPosted: Fri Jan 25, 2013 6:01 am Up
I have purchased the parts from ECP now, got air, oil filter, bosch plugs and shell 10w40 semi synth oil. Hopefulyy going to get it down later Smile
bikesforme
PostPosted: Mon Jan 28, 2013 1:22 am Up
On my 2001 1.4 8v. the only oil that my motor factors say i should use for my car is 05-40 fully synth oil.
PostPosted: Mon Jan 28, 2013 2:03 am Up
I wouldn't have gone for the red coolant or the engine flush...
PostPosted: Mon Jan 28, 2013 8:35 am Up
A bit thin & fancy for a 8 valve TU lump, it should be ok but a 10w 40 semi synthetic would be better.
PostPosted: Mon Jan 28, 2013 8:37 am Up
Mines got DAF orange long life OAT coolant in it as that's what we have barrels full of at work Laughing
System was flushed last year when it had timing belt & water pump replaced.
bikesforme
PostPosted: Mon Jan 28, 2013 12:58 pm Up
Sad
That's what i thought but that's the oil that is listed for the car at my motorfactors. Think i might use 10-40 semi next change.
bikesforme
PostPosted: Mon Jan 28, 2013 1:01 pm Up
Edward wrote:
I wouldn't have gone for the red coolant o[marq=right]r the engine flush...
I always use red coolant and engine flush in my cars and never had a problem .
spike_202
PostPosted: Mon Jan 28, 2013 6:24 pm Up
Hay buddy,
Do you no were TFM is? (Rabbit run) I get my Morris's 10/40 semi 5ltr for £15 iirc and get a oil filter from Proislee motor spears usually around £3/4 ish I do that twice a year.
**spike's project**
TEAM:+200bhp
Austin
PostPosted: Tue Jan 29, 2013 7:26 am Up
Hay buddy,
cheers for heads up mate, £15 is a bargain price! will do the same next time Smile
spike_202
PostPosted: Tue Jan 29, 2013 9:03 am Up
No probs mate in Bennets,Proislee motor spears and Livian autos all charge about £25 for the same stuff!
**spike's project**
TEAM:+200bhp
Page 2 of 2
