Forums › The Car › 206 Problems › Guide pulley on auxillary belt |
Posted: Fri Jan 25, 2013 7:48 am |
Hi everyone just a quick question on the 2.0 140 gti engine does the little guide pulley on the auxillary belt come off just by the bolt in the middle of it if so is it left or right hand thread?
Posted: Fri Jan 25, 2013 8:35 am |
Someone will be along and answer soon but if you don't have a haynes manual I suggest that you get one. Not the solution to everything but a very good guide for stuff like this and you don't have to wait for replies..
Posted: Fri Jan 25, 2013 10:27 am |
The pulley or tensioner?
If it's the tensioner you remove it by taking off the whole tensioner.
Posted: Sat Jan 26, 2013 7:58 am |
Tensioner:
First take the aux belt off by grabbing the centre bolt of the pulley (with a socket etc) and pushing back, then undo backplate retaining bolts.
Idler/deflector:
Just undo the centre retaing bolt which is normal thread.
Posted: Sat Jan 26, 2013 9:22 am |
The big bolt on the tensioner is a 16mm.
Posted: Sat Jan 26, 2013 4:14 pm |
Thank you for replies yes it was the idler some reason the wheel came off and I was just left with bearings and bolts job sorted to thanks again
