Latest: lio94
Overall: 17181
Online Now [195]:
Visitors: 194
Today: 142280
Total: 140938818
Forums › The Car › 206 Talk › Number plate fixing
Number plate fixing
Taff!
PostPosted: Fri Jan 25, 2013 11:45 am Up
Got a third world problem with my number plate in that it peels off as it's using the stick on pads. It's probably because it's in a surround but how do you guys fix yours to the car? I'm tempted to drill and use self tappers but don't really fancy drilling the boot. What have you done? Only used halfords sticky pads so perhaps they are shoddy
206 1.6 Quiksilver
PostPosted: Fri Jan 25, 2013 11:49 am Up
Mine are secured on using anti theft screws.
Use some Hammerite or other metal protection coating to stop rust on the holes you drill in to the metal work.
Taff!
PostPosted: Fri Jan 25, 2013 12:09 pm Up
I was going to use self tappers and a blob of silicone. I thought about painting but then thought the self tappers would probably etch that off anyway. Just found a cheap set in Halfords so will run with that I reckon. Thank you
206 1.6 Quiksilver
PostPosted: Fri Jan 25, 2013 12:15 pm Up
Normal number plate screws with the cars are fine. I put them in covered in grease and put rubber grommets between plate and body to stop the plate rubbing the paint.
PostPosted: Fri Jan 25, 2013 2:11 pm Up
Me too.
Reason being Greek 'licence' plates are goverment issued only and if they go walkies your shafted basicaly.
