Latest: Stu-mill
Overall: 17131
Online Now [136]:
Visitors: 135
Today: 21795
Total: 104658079
Forums › The Car › 206 Talk › door sill protecters
206gti_chris
PostPosted: Fri Jan 25, 2013 12:32 pm Up
just noticed i only have one on the drivers side, is this how they come standard or am i missing one
PostPosted: Fri Jan 25, 2013 12:52 pm Up
They where optional extra's anyway Wink
PostPosted: Fri Jan 25, 2013 1:14 pm Up
Standard fit on the GTi. Looks funny getting in a 206 without them.
Maybe your sill has been resprayed? Is there any sign of one ever being there?
DanT
PostPosted: Fri Jan 25, 2013 1:58 pm Up
Does look a bit weird getting in one without them!
They don't come off very easily but you are supposed to have a pair.
206gti_chris
PostPosted: Fri Jan 25, 2013 3:14 pm Up
good point, i need to give the car a much needed wash id know after but it looks like there's never been one on the passenger side,, bit strange then
206gti_chris
PostPosted: Tue Feb 05, 2013 8:24 am Up
gave both sills a good clean and removed tar, both look good no signs of anything odd... Fancy buying a new set though anywhere good to buy these? or just straight from peugeot
kobrakai1986
PostPosted: Tue Feb 05, 2013 11:28 am Up
On the subject of door sills does anyone know if the 308 3 door carbon sills would fit a 3 door 206 without to much fuss?
'02 206 Quiksilver. SP Kit. Gloss black 205 Speedlines. ICC Tuning WRC spoiler (civic style). Sparco Rally Flaps. Laguna splitter. Upper and lower front Struts. V-Maxx front coilovers and Apex rear shocks. GTI180 front Arb. GTI180 front brake set up. 4-2-1 Mani, 200cell sport cat, stainless pipes and sportex 3" rolled box. Gloss black morettes with yellow lenses. Yellow tinted fogs with yellow bulbs.
