Latest: SA01
Overall: 17138
Online Now [522]:
Visitors: 520
Members: 1
Today: 55071
Total: 111301451
Forums › The Car › 206 Problems › Driver side window stuck! Help please?
O111e
PostPosted: Fri Jan 25, 2013 1:12 pm Up
All my electric windows and sun roof work fine but the driver side window opens all the way but will not close all the way, I can't afford to get it fixed at a garage so is there any way I can temporarily force it shut just so I can use the car until I can afford to get it fixed? I tried pulling it up, jiggling it and pressing the button at te same time, any solutions?
Thanks,
O111e
iainlovatt
PostPosted: Fri Jan 25, 2013 2:04 pm Up
take the door card off and find out why its not shutting all the way!
(My Garage)
O111e
PostPosted: Fri Jan 25, 2013 2:12 pm Up
How do you get it off is it easy?
20Drift
PostPosted: Fri Jan 25, 2013 2:27 pm Up
Take the torx screw out of the little pocket on the door card (about half way up the door), and then unclip the card starting from the top and working down.
Or get a hammer and hit it very hard
O111e
PostPosted: Fri Jan 25, 2013 2:58 pm Up
Hmm would a flat screwdriver work on a torx screw?
iainlovatt
PostPosted: Fri Jan 25, 2013 3:18 pm Up
Nope a torx is required to remove a torx screw
(My Garage)
PostPosted: Fri Jan 25, 2013 3:28 pm Up
An angle grinder will remove a torx screw
iainlovatt
PostPosted: Fri Jan 25, 2013 4:21 pm Up
How would you remove the one in the door handle cup, muhaa
(My Garage)
meady
PostPosted: Sat Jan 26, 2013 2:31 pm Up
Trade Rating: +45
A flat head does work in a Torx bit aslong as you get the right size, there is also a few more Torx screws round the edge if the door card including one under the tweeter cover.
TEAM - I HATE FACEBOOK Smile
