Online Now [523]:
Visitors: 522
Today: 11286
Total: 146910203
Forums › The Car › 206 Problems › gearbox whine?
gearbox whine?
rus18
PostPosted: Fri Jan 25, 2013 5:42 pm Up
Hey guys, iv had a whine gradually getting worse and worse my first thought was gearbox but ive been having some minor clutch issues and wondered if the clutch could be whining like this? www.youtube.com/watch?v=zzdodqvr_qQ
tinman
PostPosted: Sat Jan 26, 2013 8:51 am Up
It does sound a bit gearbox related, does it stop when you press clutch?
Do you have a quickshift fitted?
Have you checked your gearbox oil level/type etc?
Does it make a difference hot/cold engine?
rus18
PostPosted: Sun Jan 27, 2013 12:50 pm Up
when i press the clutch down it goes quieter but doesn't go completely when coasting at slow speeds in neutral its still noticeable. No quickshift fitted and i have changed the gearbox oil to no effect on the sound, also no difference at different temperatures thanks for the reply Smile
tinman
PostPosted: Sun Jan 27, 2013 2:36 pm Up
Might be something other than gearbox/clutch if it doesnt go away when you press clutch in.
Engine?
rus18
PostPosted: Mon Jan 28, 2013 10:11 am Up
Well it doesnt whine when it's stationary only when the wheels are turning, so I was thinking diff?
tinman
PostPosted: Tue Jan 29, 2013 9:42 am Up
Does it do it in all gears?
I noticed it was when torque was going through the system so yes it could be.
'Wouldn't overhaul the whole box though just for the whine unless it's very loud & annoying.
rus18
PostPosted: Tue Jan 29, 2013 10:36 am Up
Yeah it does it through all the gears, it used to only be when in 5th but there all screaming now lol, I think il try getting hold of a second hand gearbox, do you know if there is a way to check the diff? Thanks for all your help Smile
tinman
Deano
PostPosted: Tue Jan 29, 2013 12:19 pm Up
Mine does this when in 4th I topped oil up it went then came back a day later but it's certainly not worth taking box out just yet
PostPosted: Tue Jan 29, 2013 5:02 pm Up
+1.
Check your gear-links especialy since it started only in 5th gear.
Also check the left-hand rubber gearbox-mount because once that becomes loose, the gearbox angle changes and the gear-links are not aligned properly, even if very slightly. (This also causes a 'thud' or 'gap' when starting from standstill in 1st gear and releasing clutch quickly)
rus18
PostPosted: Wed Jan 30, 2013 6:27 am Up
Thank you for all your help I will be jacking the car up later to check all the things you have mentioned.
tinman
