Forums › The Car › 206 Problems › will a gti gearbox fit an xsi |
Posted: Tue Jan 29, 2013 6:23 am |
Hi does anyone know whether a 206 gti gearbox would fit a 206 xsi? Thanks
Posted: Tue Jan 29, 2013 6:24 am |
Trade Rating: +59
Yes, but not easily or cheaply.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Tue Jan 29, 2013 9:37 am |
Okay thanks is it really that different?
Posted: Tue Jan 29, 2013 9:40 am |
Need a conversion kit, expect a few grand to set you back
Posted: Tue Jan 29, 2013 12:13 pm |
The BE4 gearbox is fitted to TU engines in the Picasso etc isn't it? So if you just want GTi ratios you'd need one of those to convert.
