Online Now [263]:
Visitors: 262
Today: 98167
Total: 145403910
Forums › The Car › 206 Problems › Steering Wheel Locking Whilst Driving :/
sxibeast
PostPosted: Wed Jan 30, 2013 6:23 am Up
Morning everyone,
Has anyone ever had their steering wheel lock into place whilst driving along?
The wife was driving her 206 (1.4 HDI 53 Reg) yesterday and the steering wheel lock kicked in mid way round the round about!
Luckily it unlocked and she was able to get off the round about but has caused her some concern (especially with the little one in the back)!
Has anyone had this happen before, and if so how did you solve it?
Do i need a new steering column? :s
Cheers,
Jon
Hello! Smile
iainlovatt
PostPosted: Wed Jan 30, 2013 6:25 am Up
First for me, Any issue with the key not going in all the way perhaps?
(My Garage)
Tolkienfan001
PostPosted: Wed Jan 30, 2013 6:26 am Up
Trade Rating: +13
I would not think it locked. I would have thought you have a power steering issue. Check the belt and fluid. Has it been excessively noisy lately?
2005 1.4 16v Sport
Check out my 206 here!
P6RAF
PostPosted: Wed Jan 30, 2013 6:33 am Up
What He Said
Tend to agree.
2004 206 HDi GTi, Obsidian Black.
VW Polo 1.3 GL - 205 GTI 1.6 - 306 D-Turbo - First 205 GTI 1.9 track car - Second 205 GTI 1.9 Track car - 106 XLD - Impreza WRX - 406 V6 - 206 HDi GTi
PostPosted: Wed Jan 30, 2013 6:44 am Up
Its 100% impossible for the mechanical steering lock on a 206 to engage while the ignition key is turned on.
sxibeast
PostPosted: Wed Jan 30, 2013 7:59 am Up
Key goes in fine all the way, no problems there and never had any issues with it.
Will check belts and fluid tonight! Car recently had a service which included fresh fluid in the pot, otherwise no noise whatsoever coming from the belt or pump!
She has reported a 'clonk' from the front passenger side suspension......could something have jammed and locked it in position do you think?
Hello! Smile
Tolkienfan001
PostPosted: Wed Jan 30, 2013 8:08 am Up
Trade Rating: +13
Snapped spring maybe? Or wishbone suspension going. Worth checking all suspension parts.
2005 1.4 16v Sport
P6RAF
PostPosted: Wed Jan 30, 2013 9:15 am Up
I suppose the obvious question is after it happened did everything return to normal when the key was taken in and out again?
Have a good look around the track rod ends and wish bones to check for anything out of place.
Also with the engine running keep turning the wheel from one side to the other and see if the fault can be reproduced. If you wanted to be really particular i suppose you should go to and empty car park and do it whilst slowly moving. Doing it stationary does put extra wear and tear on the car.
P6RAF
PostPosted: Wed Jan 30, 2013 9:17 am Up
Sorry my mistake. But the rest of the stuff should be worth a try
sxibeast
PostPosted: Wed Jan 30, 2013 11:19 am Up
Will have a check round those parts tonight i think!
Everything returned to normal after the steering unlocked which is odd!
She said she took it out for a short spin earlier and all seemed fine! She turned the wheels whilst moving slowly and stationary but could not reproduce the effect!
I am wondering if it is the spring that has gone (if i remember they are 40mm Spax springs on the front) or event he top bearing?
Thanks for your help so far chaps!
Hello! Smile
P6RAF
PostPosted: Wed Jan 30, 2013 11:47 am Up
TBH if a coil goes or bearing fails it's not going to lock the steering and then return to normal.
Is the key particularly worn ? or maybe ignition barrel ? Is the car very high mileage ?
sxibeast
PostPosted: Wed Jan 30, 2013 3:46 pm Up
Had a quick look tonight, suspension look fine, cannot see or feel any play in things that shouldnt either?
I didnt however get a chance to nose inside the power sterring fluid tank so will do that tomorrow!
Key is like new, hardly any wear, barrel feels nice and 'tight' not sloppy (no pun intended). The car is on 75K so not particularly high, especially for a diesel!
Hello! Smile
Taff!
PostPosted: Wed Jan 30, 2013 5:58 pm Up
My steering felt funny while going around two particular roundabouts which were off camber. Got a bad rear shock but it felt like it affected the steering.
206 1.6 Quiksilver
sxibeast
PostPosted: Thu Jan 31, 2013 5:13 am Up
Hmm will check the rears as well then!
I need to change the shocks on the rear anywho (and adjust the torsion bar) so will give me a good opportunity to have a proper poke this weekend!
Hello! Smile
