Online Now [206]:
Visitors: 205
Today: 56402
Total: 143046468
Forums › The Car › 206 Problems › RCL not working
RCL not working
206KL
PostPosted: Sun Feb 03, 2013 6:28 pm Up
Since I bought the 206 the rcl has not been working, I changed the remote battery today and recoded the key, but it still isn't working.
Are there any other common causes of rcl not working?
The normal central locking works fine btw.
206KL
PostPosted: Wed Feb 06, 2013 6:10 am Up
bump
iainlovatt
PostPosted: Wed Feb 06, 2013 6:20 am Up
Board could be knackered or it could ust be the fact the last owner lost the key, and tried to do what you are doing and failed..
(My Garage)
206KL
PostPosted: Wed Feb 06, 2013 9:20 am Up
is this an easy fix? Or is the price going to be so high that I may as well just use the key?
206KL
PostPosted: Sat Feb 09, 2013 10:35 am Up
Anybody got any ideas?
PostPosted: Sat Feb 09, 2013 10:38 am Up
You will get sod all help of here until you post up year of 206 you have as the remote locking fob resync instructions are totally different depending on age.
206KL
PostPosted: Sat Feb 09, 2013 2:12 pm Up
ah, my bad.
It's a 2005 multiplexed model with 2 buttons on the remote.
actionman
PostPosted: Thu Mar 14, 2013 3:33 am Up
you need to get the remote tested to see if it is actually sending an RF signal
Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes!
