Latest: Kifi69
Overall: 17183
Online Now [380]:
Visitors: 379
Today: 88756
Total: 143749216
Forums › The Car › 206 Problems › What is this pump on the GTi 180??
SinfulDesignCom
PostPosted: Thu Feb 07, 2013 3:43 pm Up
Right, the airbox that sits in the bumper of the 180... it has a pump sitting on top bracketed to the inner wing. It has a feed to the top of the air box and the other end goes... no idea, maifold I assume. I know I could ask dealer tomorrow, but I am being imaptient, and trying to plan ahead.
I can post a pic later, but someone must know. Is it emmsions control, cold start?? Can it be removed??
Many thanks...
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
Ape
PostPosted: Thu Feb 07, 2013 3:45 pm Up
Secondary Air Intake Pump. Smile
jayz206gti
PostPosted: Thu Feb 07, 2013 3:47 pm Up
Its the secondary air pump. Its designed to pull warm air into the engine from the initial start up. I read its because the exhaust levels are close to the tollerence for tests and this aids it. To be honest they are a pain. Mine is intermittent and brings the dreaded 'anti-polution' fault up if the fuel is under 1/4 tank. Im waiting for another member to be free so i can dissale it and e rid of the issue!
Upgraded from 138 to 180
SinfulDesignCom
PostPosted: Thu Feb 07, 2013 3:50 pm Up
Blimey - you boys are quick and bloody useful.
So, has anyone removed it?? Issues in doing so??
Cheers
jayz206gti
PostPosted: Thu Feb 07, 2013 3:52 pm Up
I havent removed mine, im just going to dissable it. Im sure you can remove it though....
SinfulDesignCom
PostPosted: Thu Feb 07, 2013 3:55 pm Up
Well it can easily be fed directly to the box, bypassing the pump. It is the pump I need to move because of my new air box mapping...
I can't think that it need the pump... cant really think that it will the warm feed either being a track car???
Thoughts? Thanks again....
SinfulDesignCom
PostPosted: Thu Feb 07, 2013 3:57 pm Up
Surely people replacing the airbox with a cone jobbie such as K&N etc must do without???
SinfulDesignCom
PostPosted: Thu Feb 07, 2013 5:43 pm Up
Right - latest info is that this only serves to warm the cat up on cold start to improve emissions. Nothing more. So removing it will have no adverse effects short of maybe running a little rich at times, but at least it will be burnt in the exhaust and not "recycled" pouring gasses back into the induction.
At a push, you would prematurely burn your cat out, but when you are tracking it etc, you are already through the looking glass on that score...
Will report back with any issues - thanks all Smile
Schumi
PostPosted: Mon Feb 11, 2013 12:23 pm Up
I removed them 2 year ago. There is an option in BSI settings via PeugeotPlanet2000. On customer options sub category disable aux pump. And CEL light never come up. Smile
2005 206 RC RED
SinfulDesignCom
PostPosted: Mon Feb 11, 2013 2:05 pm Up
Interesting - worth knowing. No light has come up yet - but I won't hold my breath =)
