Online Now [1271]:
Visitors: 1270
Today: 192403
Total: 149261054
Forums › The Car › 206 Problems › Nocking noise when turning
twitch169
PostPosted: Thu Feb 07, 2013 5:03 pm Up
Hi all i got alot off knocking noise coming from drivers side off car i have already just replaced droplinks track rod ends and lower wishbones and im still stumped lol if car is stood still and u turn from lock to lock probably make few nocks within that turn could it be top suspension mount ?
peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim
TheGTIlad
PostPosted: Thu Feb 07, 2013 5:32 pm Up
It could be the top mount on the suspension, it could also be a deformed spring aswell, causing the spring to jump out of place whilst turning through lock to lock.
To check if its suspension related, get someone with a torch to look at the spring with a handlamp/torch to some description and turn the steering lock to lock and see if the spring jumps suddenly at all. Hope this helps you!
PostPosted: Thu Feb 07, 2013 5:37 pm Up
CV joints, probably worse if your driving and turning full lock.
twitch169
PostPosted: Thu Feb 07, 2013 5:43 pm Up
its hard to tell its doin my head in now lol
twitch169
PostPosted: Thu Feb 07, 2013 5:44 pm Up
it seems to be louder when sat in car
PostPosted: Fri Feb 08, 2013 12:56 pm Up
Loose streering rack?
twitch169
PostPosted: Fri Feb 08, 2013 3:44 pm Up
yh might have to check that
Wayneone
PostPosted: Fri Feb 08, 2013 5:25 pm Up
My money is on driveshafts..
twitch169
PostPosted: Sat Feb 09, 2013 4:01 pm Up
If it was drive shaft it would be a constant nocking while turning so say u go round a roundabout it wid constantly nock right ? But mine only nocks while actually turning the wheel so if i turn it will nock but only as ive turned the wheel not while goin round the corner. Does any one think it could be the 2 ARB anti roll bar bushes cart be drop links as i said ive changed them both
PostPosted: Sun Feb 10, 2013 6:58 am Up
Broken spring?
Wayneone
PostPosted: Sun Feb 10, 2013 7:53 am Up
Ahh right ive had this problem with a 106... What it turned out to be was the dampener nut. It needs to be super human tight. If your cars at standard ride height you can get a pipe wrench i between the spring. When i did mine i only managed to get 1/4 turn on it but that was enough to stop it knocking. Give it a try and get back to us all. Smile
twitch169
PostPosted: Sun Feb 10, 2013 11:22 am Up
Right i gunna try that was thinking could it be that lol no car is lowerd so i gunna struggle getting my hand in lol might get air gun on it if it works i will solve this problem lol
Wayneone
PostPosted: Mon Feb 11, 2013 8:38 am Up
You may have to take the strut out then. You need a 3 pin spanner thingy. You may get away with using the tool to take the disk off a angle grinder. I use a plumbers pipe wrench and a long bar which ive named excaliber Smile
Fifer
PostPosted: Mon Feb 11, 2013 3:09 pm Up
My suspension bearing symptoms were intermittent knock on full lock and if stationary and I turned the wheel I would get a knock. Not always at the same place. I could feel the knock slightly through the steering wheel.
you can check by having someone turn the steering wheel and watching the spring. It will jump with the knock. The bearings can be purchased for about £15. Undo wheel. Undo drop link. (I had to grind mine off but was changing anyway). Undo strut bolt. I had to jam the nut and using an allen key turn the strut shaft until nut comes off. Compress spring. (This was also a nightmare due to the progessive spring. I couldnt get the spring pulled down far enough with my commpressors.) At this point you can undo the strut holding bolt if you are goi g to remove the strut ( I couldnt it was siezed solid). Next undo 3 small bolts at top of strut and I slid the top mount out past the strut. Remove old bearing and
reverse to put baxk together.
edited to add. My bearing just fell out it was totally destroyed. I have since been told that 2 sets of compressors allow you to pull the spring down further to reach in. Not sure if this would work with lowered though.
If you are not removing the strut make sure you have a decent set of spring compressors otherwise its really hatd to get the top mount back in place and the spring mounted on it correctly.
1.4hdi 02
