Latest: tbafonso
Overall: 17130
Online Now [78]:
Visitors: 77
Today: 14227
Total: 103836549
Forums › The Car › 206 Problems › Aux belt to be changed - UPDATED - Now changed :D
Tolkienfan001
PostPosted: Sat Feb 09, 2013 2:39 pm Up
Trade Rating: +13
Guys I need to change the Aux belt on my 2005 1.4 16v.
I have checked on here but I can't find a how to. Does anyone know if there is one. Or can you tell me what to do. Not sure which is the tensioner and how to release it?
2005 1.4 16v Sport
Check out my 206 here!
Andy_
PostPosted: Sat Feb 09, 2013 3:46 pm Up
Id get someone to do it who knows what there doing. No offense
Progress Thread
PostPosted: Sat Feb 09, 2013 3:58 pm Up
If it's an automatic tensioner just put a ratchet on reverse onto the bolt, slacken it and pull the belt off
If it's manual (I can't remember what / if any 206s have these as it's normally without belt power steering) undo the bolt on the alternator, push it back to loosen the belt and remove it.
Just remember what way it went on the pulleys - and it may be very tight to get back on I often have to use a breaker bar to get enough leverage for the tensioner to fit the new belt on. Isn't difficult, can be done in 2 mins
PostPosted: Sat Feb 09, 2013 4:19 pm Up
Just need a 16mm spanner on the tensioner on a GTi...yours might be the same.
PostPosted: Sat Feb 09, 2013 5:12 pm Up
16mm on both my GTi's & my 1.4 was the short extension into the tensioner and pull.
Tolkienfan001
PostPosted: Sat Feb 09, 2013 11:22 pm Up
Trade Rating: +13
None taken. Now I've read the other replies, I am someone who knows what they are doing. Wink
2005 1.4 16v Sport
Tolkienfan001
PostPosted: Sat Feb 09, 2013 11:23 pm Up
Trade Rating: +13
Thanks guys. I will get it sorted after work. Smile
2005 1.4 16v Sport
PostPosted: Sun Feb 10, 2013 5:59 am Up
So often I think the right answer is buy a Haynes manual.
Tolkienfan001
PostPosted: Sun Feb 10, 2013 7:04 am Up
Trade Rating: +13
Yea I've had a look in the Haynes now seems to make sense..... We will see Smile
2005 1.4 16v Sport
Tolkienfan001
PostPosted: Sun Feb 10, 2013 8:35 am Up
Trade Rating: +13
Some of you might laugh, but I am really proud of this!
I have never done any work on my cars before getting my 206 in Oct last year. I have now changed the discs pads. Aux belt. Track rod ends next. Smile
I read through the Haynes manual. Went to the car took the old belt off. Routed the new belt from memory! Very Happy
Then sweated grunted and shouted as I held the tensioner and put the last section of the belt on the last roller / pulley. Wink
Thanks for all the help and advice!!
2005 1.4 16v Sport
PostPosted: Sun Feb 10, 2013 11:11 am Up
Track rod ends should be relatively easy.
Why are you changing them?
After changing them get a full four wheel alignment done. The more sensitive equipment will measure the rear (they never point where the manufacturer intended) and that will be taken into account when setting the front. Although you are on a four point machine you will only pay for what is adjusted so that should be about £35.
Tolkienfan001
PostPosted: Sun Feb 10, 2013 11:17 am Up
Trade Rating: +13
The ns one has a lot of play. The os one has no play but the rubber has collapsed. So thought I may as well do both.
My local garrage does 4 wheel alignment. So that should not be a problem.
2005 1.4 16v Sport
PostPosted: Sun Feb 10, 2013 12:51 pm Up
Advice for track rod ends, get a blowtorch or a very strong source of heat, if they havent been touched for a long time, they like to seize inside the track rod.
i did one last year it wasnt until i had the track rod glowing hot that it finally moved.
Tolkienfan001
PostPosted: Sun Feb 10, 2013 12:55 pm Up
Trade Rating: +13
600c heat gun then Very Happy
2005 1.4 16v Sport
