Latest: Beduff1977
Overall: 17134
Online Now [596]:
Visitors: 595
Today: 85096
Total: 108717281
Forums › The Car › 206 Problems › relay wiring.X reg 206. 1.4 8v single fan
apexuk
PostPosted: Sun Feb 10, 2013 8:54 am Up
Hi there i seem to of had the same problem as alot of 206 owners were the wiring to the fan relays has corroded away and the wire's just hanging there. My problem is the second relay below the one at the top has no wires to it i have replaced all the connectors and it's ready to go but i am not sure where each wire connects back to there are 4 wires in totall i did try but when i disconnected the sensor plug the fan started blowing on it's own then when plugged back in the fan would stop so i have just disconnected it for now to see if someone on the site knows the correct locations for each wire. I have used another members image just to show you which relay it is. sorry if i sound clueless it's because i am. Any help is very greatful i did try looking around the internet and on this site but did not find anything helpful also tried to zoom in on the image but it just distortes so i cannot see clearly. In the image its the second relay in the section labelled 1.
[img]
[/img]
WGH
richpowell91
PostPosted: Sun Feb 10, 2013 9:24 am Up
So you want to know which wires go where into the relay? Still got the black connector block that connects to the relay?
apexuk
PostPosted: Sun Feb 10, 2013 9:32 am Up
i do have the block but i tried looking at that also but it's just full of green dust lol not a hint of coloured wires to be seen
WGH
apexuk
PostPosted: Sun Feb 10, 2013 9:33 am Up
i have noticed also there are 5 connection points on the relay but only 4 wires to connect ?
WGH
richpowell91
PostPosted: Sun Feb 10, 2013 9:46 am Up
Yeh thats right, just looked at the haynes manual and also the old relay the numbers tally so:
Number 1 pin: Red
Number 2 pin: White
Number 3 pin: Beige
Number 4 pin: N/A
Number 5 pin: Orange
Thats how mine is wired
apexuk
PostPosted: Sun Feb 10, 2013 9:50 am Up
Thank you very much for your help soon as this weather settles i will go try may be a while lol.
Once again thanks Smile
WGH
richpowell91
PostPosted: Sun Feb 10, 2013 9:57 am Up
It should have the pins numbered 1-5 on bottom of relay if its a cartier relay (one peugeot sell). Haynes manual 12.30 diagram 4
