Latest: tebas93089
Overall: 17179
Online Now [134]:
Visitors: 134
Today: 10217
Total: 138529977
Forums › The Car › 206 Problems › Comms 2000 and Horn
Comms 2000 and Horn
4wheelwonder
PostPosted: Tue Feb 12, 2013 11:12 am Up
Last week the comms 2000 unit cable became defective, giving an Air bag fault, so a replacement was sourced through the 'bay. This turned out to be slightly different with a socket missing on the back, so I cut the umbilical cable off the newer one and soldered it in placed of the old one. The soldering was checked and no shorts seen.
After been fitted back to the car, and the battery connected, the horn sounds continuously. The only way to silence it is to disconnect the battery again.
Does anyone had an idea on what could be amiss?
and..
Where is the damn fuse for the horn?
The car is a 2005 206cc 1.6 Allure
Many thanks for looking..
PostPosted: Tue Feb 12, 2013 11:36 am Up
Buy a NEW com 2000 unit, stop messing around trying to bodge 1 together.
Your lucky you didn't fire the drivers airbag of!
Euro car parts sell new Valeo Com units pretty cheap.
4wheelwonder
PostPosted: Tue Feb 12, 2013 5:23 pm Up
Thank you for the reply. I shall give them a bell in the morning because their website does not show the part.
And to the other question, where is the fuse to the horn?
jayz206gti
PostPosted: Tue Feb 12, 2013 5:41 pm Up
It does show the part, ive seen it myself
Upgraded from 138 to 180
Tolkienfan001
PostPosted: Wed Feb 13, 2013 1:06 am Up
Trade Rating: +13
Part is under switches. Although I have a comms 2000 for sale for £50. The rear wash wiper ribbon needs attaching to the board again, as it has come off if you are interested. Everything else works.
The fuse is passenger side fuse box no. 13 I believe.
2005 1.4 16v Sport
Check out my 206 here!
4wheelwonder
PostPosted: Wed Feb 13, 2013 5:58 am Up
Again, Thank you for the replies.
Euro Car Parts do not have the part, and have no forecast on its availability.
Tolkienfan001, thank you for the offer. I will mention it to my brother (his GF's car, not mine). A different Comms unit has already been tried, and this brought up a ABS error. Been the hairdressers model, it does not have a rear wash.
The part number required is 96595097XT
Many thanks for the assistance
PostPosted: Wed Feb 13, 2013 6:03 am Up
Where's that part number from?
According to ECP they have all the Com2000 units in stock for delivery. Without knowing anything about your car, then it's hard to tell you which one you need from them. You need to look at each one and check it's functions eg front fogs, trip computer, auto function etc. They might not have it locally, but they will have it the next day for you
PostPosted: Wed Feb 13, 2013 6:05 am Up
That's NOT an actual Peugeot / Citroen part number, that's just the number you have found on the com unit Wink
PostPosted: Wed Feb 13, 2013 6:20 am Up
From memory, com units are 6242**. Can't be bothered to look how many variants there are, but probably more than 5
4wheelwonder
PostPosted: Wed Feb 13, 2013 7:10 am Up
Hi,
I phoned them up with the number off the actual unit.
Right then, further I have found that the number from the dealers is 6242.H6, and they want £340ish for it.
PostPosted: Wed Feb 13, 2013 10:37 am Up
4wheelwonder wrote:
Hi,
Euro car parts will be able to sort you out with a nice new Valeo unit much cheaper then a Peugeot main dealer Wink
Give Euro the Peugeot part number & / or the functions of your current com 2000 unit.
4wheelwonder
PostPosted: Wed Feb 13, 2013 12:42 pm Up
It is Euro Car Parts are saying they do not stock that part.
One has now been sourced, "WITHOUT REAR SCREEN WASH WIPE AND WITH ELECTRONIC STABILITY PROGRAM"
Fingers crossed that her car will be on the road again at the weekend, I want 'my' car back Sad
Many thanks for the information, it has been very informative.
