Latest: tebas93089
Overall: 17179
Online Now [133]:
Visitors: 131
Bots: 2
Today: 8321
Total: 137973938
Forums › The Car › 206 Problems › Fault codes.
Fault codes.
Anthonys206
PostPosted: Sat Feb 02, 2013 10:52 am Up
Hi all, I recently bought myself a 1.4 look and finally got round to putting the fault scanner on it today. I got codes, po130, po131 and po145. Any advice on how to fix? Cheers.
PostPosted: Sat Feb 02, 2013 3:15 pm Up
Well all the three fault codes related for a faulty Oxygen sensor,the faults P0130 and P0131,is related for the upper oxygen sensor,to check if it have a bad connection,or corrision on it's plug,how many miles on the clock??
if your car is old like 2001-2003 with high mileage,I would say you would need a new oxygen sensor,do you have the EML light on ??
About the P0145 fault code,it's related for the lower oxygen sensor,or oxygen sensor number 2,but this might be cause because the first one is faulty,so fix the first one,and see if this fault stays.
Anthonys206
PostPosted: Sat Feb 02, 2013 3:33 pm Up
Thanks for that. It's a 52 plate with about 74k on the clock. Yes the eml light is on.
PostPosted: Thu Feb 14, 2013 2:41 pm Up
well did you got it fixed?
