Online Now [302]:
Visitors: 301
Today: 83967
Total: 142594379
Forums › The Car › 206 Problems › heeeellllllllpppppp!!!!!!!!
Go to page Previous  1, 2
parker81
PostPosted: Fri Feb 15, 2013 4:38 pm Up
i was told that by 1 of my friends but already checked all that out and still nothing? could it be something to do with the immobiliser?
PostPosted: Fri Feb 15, 2013 4:49 pm Up
Yes it could. But what were the codes?
Never erase codes unless you write them down first, and then only if you've performed worked that might have solved them coming-up in the first place.
Also, after three conseqative attempts to start and no-running, the anti-scanning cuts-in and won't allow the ECU to be unlocked hence no-spark.
Other possible causes of no-spark could be rellay under ECU faulty, loom fault/interminent connection, immobiliser fault, and immo chip in the key not being detected by the key-barell aerial and BSI.
'Hope you sort it.
parker81
PostPosted: Fri Feb 15, 2013 5:18 pm Up
the car beeps when the key is in and the door is open, cant find the code list as the wifes been clearing up .... checked all the relays and they seem fine on multi meter
Page 2 of 2
