Latest: tc.206
Overall: 17147
Online Now [132]:
Visitors: 131
Today: 27891
Total: 116373352
Forums › The Car › 206 Talk › Top Mount Bearing
Top Mount Bearing
Austin
PostPosted: Fri Feb 15, 2013 1:32 pm Up
Alright guys, I need to change my top mount bearing, went on ECP and ordered the following part...
CLICKY!
But it looks like just the top mount without the bearing :/ can someone clarify and point me in the direction of getting a bearing? I need front O/S, car is a 2004 1.4 8v.
Cheers
Austin
PostPosted: Fri Feb 15, 2013 1:36 pm Up
www.ebay.co.uk/sch/i.h...&_from=R40
Like these?!
PostPosted: Fri Feb 15, 2013 1:39 pm Up
Also, use carpart4less.com
Same website, slightly cheaper, unless you can get any promo codes.
Austin
PostPosted: Fri Feb 15, 2013 1:51 pm Up
Are these the ones I need??
CLICKY!
PostPosted: Fri Feb 15, 2013 2:20 pm Up
Yes.
spike_202
PostPosted: Fri Feb 15, 2013 3:55 pm Up
Why not just buy the hole top mount? They are only like £30-£35, I had both mine done end of last year, its always worth doing this sort of thing in pairs as you know they are both good, rather than do one then do the outher when that goes.
**spike's project**
TEAM:+200bhp
Austin
PostPosted: Sat Feb 16, 2013 3:08 am Up
I have got both the top mount and bearing now. Is there a how-to guide anywhere on how to change these??
spike_202
PostPosted: Sat Feb 16, 2013 5:06 am Up
Have you ever changed your front suspension before? If so its the same steps just get the strus off then you change them then its quite simple if you have spring compressors and the correct spanners/sockets. A garage should be able to both in under 1hr
**spike's project**
TEAM:+200bhp
Austin
PostPosted: Sat Feb 16, 2013 12:01 pm Up
I have done a few spring and strut changes before but I'm just not keen doing it myself this time round. Got a feeling the drop links and bottom ball joint are gona be a pig to get off :/ will get a price off garage to do it, cheers though mate Wink
