Online Now [1209]:
Visitors: 1208
Today: 278242
Total: 149339926
Forums › The Car › 206 Problems › Knocking when going over bumps
A10PSW
PostPosted: Wed Feb 20, 2013 1:14 pm Up
I am loosing patients with my 2005 Pug 1.4 HDI. The clutch and gearbox has been taken out and put back in 3 times now due to a input shaft bearing, a worn clutch and again because the new clutch was faulty.
Now i have got it back I have noticed a knocking coming from the offside when I go over a bump and also a clunk when I turn on full lock.
Could this have been caused by the work that has been done?
Any ideas anyone?
Tolkienfan001
PostPosted: Wed Feb 20, 2013 1:23 pm Up
Trade Rating: +13
Sounds like suspension. Lower arm, top mount, spring etc.
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Wed Feb 20, 2013 2:30 pm Up
Sounds like CV joint for the full lock knocking, and also bottom arm or droplinks for the knocking, likely to be related to the gearbox.
PostPosted: Wed Feb 20, 2013 2:34 pm Up
well i guess the Gearbox mount is your problem,maybe it went faulty by the work done to the gearbox,so check it
PostPosted: Wed Feb 20, 2013 2:35 pm Up
it's located under the battery tray
PostPosted: Wed Feb 20, 2013 2:36 pm Up
Doubt its the gearbox mount, wouldnt suddenly go, unless it was damaged somehow when the gearbox was removed.
colganraz
PostPosted: Wed Feb 20, 2013 3:55 pm Up
Could also be just a worn bush allowing excessive play!
Former 206 XSi owner - Now 207 GT
www.206info.co.uk/Foru...56475.html
A10PSW
PostPosted: Thu Feb 21, 2013 9:32 am Up
See this short video I took when I push the NSF wing up and down...
Click below
Knocking video
NayNay1991x
PostPosted: Thu Feb 21, 2013 1:55 pm Up
Could be a bush yea
206 1.4i GLX 1999
instagram.com/nay206pug/#
PostPosted: Thu Feb 21, 2013 6:01 pm Up
Doesn't sound like a bush, are your shocks really bouncy?
Check the top mounts for any movement, a bush wouldn't really make that noise, not from bouncing anyway. I suppose t could be an engine mount, I looks like your engines moving, but cant really tell. If it is then its more than likely engine mount. See for any movement back and forth when revved. You can expect a bit, but not loads.
A10PSW
PostPosted: Sat Mar 02, 2013 5:53 am Up
Turns out this was just the inner wheel arch lining which was not secured.
