Latest: jackrox1992
Overall: 17186
Online Now [1152]:
Visitors: 1151
Today: 13644
Total: 148782967
Forums › The Car › 206 Talk › Thrust bearing....
Thrust bearing....
Forum Index › 206 Talk
TheWhiteRasta
PostPosted: Thu Feb 21, 2013 3:22 am Up
Hello, can anyone tell me if the trust bearing on the 206 180 is the same as on other Models? My local parts supplier doesn't have one specifically for my car just the clutch kits. I can get just the bearing for other peugeot models. Cheers
PostPosted: Thu Feb 21, 2013 3:39 am Up
Your parts supplier should be able to tell you because if they are the same as other models, they will share the same part number in the catalogue.
If your parts supplier can't get the right part ordered in for you, then change suppliers.
Personally, if I was going to the expense/time and effort of taking the gearbox out to change the thrust bearing, I'd replace the clutch at the same time. No point doing half a job.
TheWhiteRasta
PostPosted: Thu Feb 21, 2013 3:52 am Up
I will try somewhere else. I haven't got the box off yet so might end up changing the whole thing. I don't like doing things by half it's just I paid a garage to change the clutch about 20,000miles ago and now it's squeeling like a pig.
206 GTI 180
Micra 1.3 Turbo
