Online Now [511]:
Visitors: 510
Today: 136829
Total: 144956993
Forums › The Car › 206 Problems › Fan only working on 4 - Heater resistor?
Matt106
PostPosted: Wed Feb 20, 2013 8:35 am Up
After doing a little digging I believe that my heater resistor has failed as I only have the use of setting 4 on the fan.
Where's the best place to buy another resistor and is it a fairly easy fix?
This is the first job in a long string on jobs that need doing on a car I've just got!
206 XSI
PostPosted: Wed Feb 20, 2013 9:14 am Up
Yes.
AX-Rated
PostPosted: Wed Feb 20, 2013 9:45 am Up
Get another fan. The resistor isn't just some little farty thing you see on circuit boards.
Plus finding one with the exact resistance values with the correct steps you give you the different speeds would be difficult at best.
Black 03 GTi
Matt106
PostPosted: Wed Feb 20, 2013 10:00 am Up
so one of these? - www.ebay.co.uk/itm/PEU...5d3a0cd1e8
206 XSI
PostPosted: Wed Feb 20, 2013 10:12 am Up
The resistor pack is available as a spare part for PSA stuff without climate control fitted.
Last time I checked the price new from Peugeot / Citroen they where pretty cheap.
PostPosted: Wed Feb 20, 2013 3:20 pm Up
The resistor has melted, along with probably the earth on your connector
End thread.
Matt106
PostPosted: Thu Feb 21, 2013 4:40 am Up
Not exactly end thread, is it easy to access and replace?
206 XSI
AX-Rated
PostPosted: Thu Feb 21, 2013 7:42 am Up
Well tickle my tits til Tuesday. Learn something every day.
Black 03 GTi
PostPosted: Thu Feb 21, 2013 4:54 pm Up
Probably, stab in the dark with a pork sword
6.5 out of 10 easy
