Forums › The Car › 206 Talk › Trim inside boot... |
Posted: Thu Feb 21, 2013 10:33 am |
does anyone know if there should be any plastic trim on the boot lip / around the boot latch as the what i presume is the alarm switch is all exposed and prone to being knocked
Posted: Fri Feb 22, 2013 8:57 am |
Pic of the bit im wondering if it needs to be coverd/should be coveerd
Posted: Fri Feb 22, 2013 10:20 am |
No there's no trim. Just put the rubber boot back on the plug.
