Latest: tbafonso
Overall: 17130
Online Now [47]:
Visitors: 46
Today: 4058
Total: 104128874
Forums › The Car › 206 Problems › gti 180 oil pressure light
gogs_macaulay
PostPosted: Fri Feb 22, 2013 6:34 pm Up
is there one? or is that what the "stop" light is? all cars i have had before the oil pressure light stays on before u start the car then goes out once started(little red oil can light). no oil pressure light lights before i start my 180
PostPosted: Sat Feb 23, 2013 1:55 am Up
These work differently.
PostPosted: Sat Feb 23, 2013 5:41 am Up
This is perfectly normal for a multiplexed 206 Wink
